JUST STOLEN 30 MINS AGO - R32 GTSt with GTR engine stolen from XTC, preston just off Bell St
Reported that car had next to no fuel.
If you have spotted this car fuelling up or in the area please call mobile number below
Car was taken approximatly 10pm on 4/5/05
Please call on 0425 818 755
PICS
http://img236.echo.cx/img236/4810/ther32front17xx.jpg
http://img236.echo.cx/img236/6829/ther32side110xn.jpg
http://img236.echo.cx/img236/6133/ther32stick119io.jpg
https://www.sau.com.au/forums/topic/72518-stolen-endless-r32-gts-t-with-rb26/
NS.com Link
If everyone could please spread the work someone will know something..... ENDLESS is a unique car that is treasured, originally built by Garage Endless in Japan....
Large REWARD offered for information leading to arrest, all leads will be kept strictly confidential.
Sam.
RIGHT IN FRONT OF SHOP under BRIGHT STREET LIGHT.... Nick was on dyno, I was at Meggala's... he heard it start by the time they ran out the front to chase had already left the street and heading down gaffney st :(
Sam.
Thanks Guys.
I am the owner of Endless - it was stolen from the XTC workshop in Coburg around 10pm tonight 4-may-2005.
I understand the key was still in the workshop and I understand little fuel in the car.
As Sam mentioned - a generous reward will be provided to anyone with information leading to arrest or recovery of the vehicle.
All information will be treated confidentially.
Any info (sightings / rumors of whereabouts/ etc) should be forwarded to me on 0421 058 259 or [email protected]
If you see the car - please contact Coburg police station on 9350-4755 asap
Thanks for the support from SAU guys - those that have posted and thanks in advance for those that do. It is a beautiful specimin of an R32 GTSt, with some pricey mods inside such as RB26dett & aftermarket gearset. An Apexi drag intercooler, buddy club drag spec suspension, and a twin plate HKS clutch were some of the items on board.
Car has standard interior and is silver in colour with aftermarket 17" rims (refer to photos in top post or visit Endless Pics for pictures.
It is very dissappointing there are people out there that do this.
Please ensure the same does not happen to you!
Best regards,
David (aka RoundEye, aka Mr killowatt)
PS: GTR donations will be accepted from any rich fu$$ers with a big heart :(
oh the old endless :cheers:
Thats the only car to this day that has been able to purely scare me to the point of disbelief.
Even though its no longer in that state... still i can understand the love and need for it!
Hope you find it Dave
-Ash
That's terrible Oyabun san :cheers:
Hope a swift and firm kick in the balls is dealt very very soon to these dogs.
I saw Troy on the weekend - he mentioned you were back from OS and in SA.
Are you in town?
Thanks Guys.
Hahaha, I like that one, sorry to hear about endless. I hope you can get something back from whoever responsible for the car or recover from the Police :cheers: . But I think it is mostly gone interstate, maybe you should also try to look around in SA.
Good luck man
Regards,
IMPUL and LEMANZ
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
