  • Replies 102
The Nur is not a real Nur. As far as I know there are only 2 of them in the country, a third one arrives fairly soon. The guy found out about the event the night before and took it to a carwash that morning where they did a very average job on it.
I think only an owner knows how to get his/her car properly clean.
Satanic said he put 4 hours into cleaning his car, which he thought was a lot. I put 6 into mine to not even enter it. I know some would have put up around 20 over a few days.
The Judges could tell who had put the effort into cleaning their car and the points were appropriately awarded.
i put about 2 days into cleaning mine. took me 4hrs the wheels alone!
jayce, your not working are you? it would explain why you've posted so much over the last couple of days, ya bum!
Breather between old job and new job...
Does anyone have any pictures of it front on where you can see the bonnet? From the quick glimpses I have seen, it doesnt have the NACA duct on the bonnet which would mean its not even a V-spec II (unless its had the bonnet replaced)?
Still, id give my nuts for a BNR34 :wassup:
Oooh and gracer still exists... I havnt seen that car around for a while, possibly one of my favourite GTR's of all time (not sure why, I just love it).
"GRACER" started life as an R33 GTS-T,by the way...
A-HA! The game is up! I just knew  he was a poser of the highest order...Is he on the forums at all?
That's a bit harsh. Damn Struggletown dwellers... Just kidding.
I had a bit of a chat with the owner and he admitted to me in his first sentence that it wasn't a real one. Also I didn't ask him where he bought it but I think I know the car from before. Powerplay imported it and then it belonged to a guy in Qld. Powerplay then resold it probably to this guy. It was the Qld guy who turned it into a Nur.
He is not on the forums but he did join the club on sunday. Owns a wrecking yard I think.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
