Hankook Ventus V12 EVO in 215/45R17 (fronts only)
Cost: $206ea
Dry Handling: Holds on really well through the corners, not much noise at all. Can't really compare to many other tyres as these were pretty much the first set on my 17"s.
Wet Handling: Also very good. Not much understeer through corners and actually grip really well, suprisingly.
I can't really give a proper rating since I haven't had much to compare to in performance tyres, but I would definately get another set of these.
Fitted Hankook Ventus R-S2's to the rear of my car yesterday. 18/40/235 on my 18x9.5 wheels (stretched fit)
wear rate is 200, but so far very good! wet weather was good, stable. and in the dry, they hold 350 odd RWKW's well.
  • 4 weeks later...
lol...Federals in the wet... better be paying attention!
in the dry they grip okay if you want to go in a straight line... forget about corners... make lots of smoke though:)
michelin pilot sports get my vote, even when secondhand they run rings around the Federals (thanks ZigenGT)
i agree the federal 595 SS are not that great. not too bad in the dry (6/10) but quite crap in the wet (4.5/10) mainly coz i think they hav quite a hard compound rubber but they do last quite a long time and are great for drifting and burnouts and they r fairly cheap. the federal 595 RS tires are awsome (265/35/18) 423hp at the wheels and no wheelspin in 2nd gear and only a bit in first and very grippy in the wet too. for $325 a tire im definately not complaining id say dry (8.5/10) wet (8/10)
The 595RS-R grips best when it is at 60 - 80C on the tread face, normally you wouldnt be able to generate that kind of heat on the street (unless you were driving very hard for a long time on a hot day).
However, compared to normal street tyres the 595RS-R will provide much more dry traction even when cold.
I use the RS-R's for street and track use and I dont think I will be able to go back to street tyres now, there is just so much grip available with them fitted to my Skyline... If you want extreme traction for the street you would be very happy with a set of 595RS-R's.
BTW - I have managed to get 30,000kms+ from a set of 595RS before - which goes to show that you can get good mileage from them. :P
i agree 595 RS will chop a 595 SS in grip no matter wat.
Edited by daineisdabomb
Got a choice between Federal 595SS or Toyo T1R in 225/50R16's for my new GTR..
Mainly for daily driven road use for now.. May see a track day later on if I haven't gone for larger rims by then.
Which one should I go for? Or much of a muchness. Price difference isn't too much between them. Both seem to be fairly favoured on here.
T1R for sure!! although they r probably a bit more expensive than the feds. softer compound i recon n awsome grip
Kumho KU31 (Previously owned)
225/40R18
Dry Handling 7/10
Wet Handling 7/10
Value 8.5/10
A good mid-range tyre that suited road use fine and are great for a car without too much power. They got a tad noisy but value for money you can't really go past them.
Ling Long somethings (Put on to get compliance, not my choice!)
Dry Handling 3.5/10
Wet Handling 1.5/10
Value 3/10
I guess you get what you pay for. Extremely hard compund, noisy and very little grip. Also hard to balance. The very next day after I got my car I took it into work and had to get them balanced again. It took a good balance from a very good balancing machine (Hunter Road Force) before I could get them to spin up nicely.
When I get some new wheels/tyres I will either be upgrading to Toyo Proxes R-1R's or Pirelli PZero Rosso's (Depending on what I can get the Pirellis for).
LING LONG, the name says it all lol.
Can anyone give me an impression on
Yokohama Advan Sport V103
Michelin Pilot Sport PS2
Bridgestone Adrenalin Potenza RE001
And price if anyone has brought these
Hey guyz can anyone tell me how these tyres are because i have to go for a track day in 2 weeks and need to decide on tyres.. The only reason is i have a tight budget and cant be spending to much.. ->DUNLOP LM702
If anyone knows of any good tyres that i could just use for the track day and something thats not to expensive please let me know!!
Hankook Ventus Sport (K104)
Dry: 6/10
Wet: 7/10
Value: 9/10
These tyres are just value for what you pay for. I did lose alot of traction though when putting the foot down until third gear. I paid around $200 at the time for 17s.
Hankook R-S2
Dry: 7/10
Wet: 8/10
Value: 8/10
Pretty much like the K104 but alot better traction - tends to chirp more than lose traction. These tyres are more to my liking for someone that only uses the car to get from A to B with a rare splash now and then. I paid $260 for 17s.
Toyo T1-R
Dry: 8/10
Wet: 9/10
Value: 7/10
Damn these were expensive, but I have to say that you really get what you pay for because these are fantastic! Honestly though, I would get cheaper tyres as I'm no racer and I don't drive around town like a hoon so all this great grip does nothing for me. I paid $450 for 19s.
im running 595RS, 235/45 all round. so no huge grip on the rear.
on the track they grip up 1-2 laps before the guys running r comp tyres. so your right up the back of those guys until they grip up.
been to philip island twice and both times it has pisssssled down. the tyres amazed me, there is no way i could turn into turn one at the same speed
with normal street tyres.
done 7'ish days so far on these tyres. the center grooving has heaps on meat left. the outer grooving is wearing, to the point now were you cant really
see the outer grooving. (not running enough camber and the tyre is rolling over on the fronts.). have been rotating and swapping the rubber on the rims.
RS-R = 140 tread wear rating
RS = 180
KU36 = 180
Iam considering RSR's for the front of mine but not sure if they are overkill for what I use my car for. I would get the KU36's but they dont make them in my size.
Tim.
Yea car is used on weekends and for motorkhana's, drags, hill climbs etc. I know RS-Rs would be great for these events but they also need to do about 5000 ks per year on the road.
I will have a look into the rt615's. i was quoted 310$ per tyre for 255/35/18's for the RS-R's which is the size i need. I dont think that is a bad price?
Tim.
R32 GTS-T
Falken Ziex
235/45/R17
Did not like these one bit, cheap at $170 per wheel
Front end was bouncing all over the road, not much grip on the rears at all in the wet or dry.
I had some fun times running these on the rear while they turned to slicks lol i strongly do not advise !!!
Wet 4/10
Dry 5/10
Toyo T1R's
Ohh baby ive had these on the rears for around 1yr and they still have meat left on em, and still grip quite well :(:P
Wet 8/10
Dry 9/10
Next tire is going to be the Toyo R1R's on rear at 245/45/R17 in the coming weeks.
While i rotate those bad boy T1R's to the front :P @ 235/45/R17
anyone on the big car forums have good Toyo deals? these T1r's sound good.
How would people rate/compare the
Federal 595 RS-R to the KU36? - In the boat of mostly street, with 2-3 track days a year (grip, not drift or drag)
Edited by SS8_Gohan
Hi, do you know how to improve braking & handling?
When I stop from 100kms to 30kms in short distance, the tail shake left & right and unstable.
Any ways to improve body stable?
Also, what is the best tyres for track racing for 19"?
ANG32
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
