That 20B was insane and went 9.08 @ 146.26 in the next lane. I couldn't hear my car for the first 100' - it was ridiculous.
On of the marshalls came over to ask if i'd mind racing it. I simply asked if it had been going straight all day and when she said yes, I said hell yeah. :)
Adrian
  • Replies 152
Top effort Adrian, looks like some more work in the shop before she is out again doing some more PB's.
Post up your full 11.9 and 11.8 details. How do they compare to the first 11.9 you did awhile ago? Picking up any mph or lowered that 60ft any further?
Well done Adrian. Cooler pipes are a farking menace, do you have silicone piping? Tridon make some great heavy duty style clamps which are what you need, they basically use a hge bolt to pull the two sides together, the clamp itself is about 12mm across :) If you can't keep a pipe on with them you cant keep a pipe on. Pirtek stock them
Today:
R/T - .186
60' - 1.887
330' - 5.163
660' - 7.816
mph - 93.80
1000' - 10.086
ET - 11.986
MPH - 116.41
R/T - .317
60' - 1.788
330' - 5.039
660' - 7.689
mph - 93.90
1000' - 9.955
ET - 11.852
MPH - 116.47
Previously:
60' - 1.697
660' - 7.734
mph - 92.46
ET - 11.959
MPH - 117.18
Just over a tenth in improvement but almost a tenth outside my best 60' time. These new tyres are better so with a 1.65 I'm hoping to see 11.70 as is.
Adrian
The commentator probably just saw "Supra Motor" and made the jump himself.
Anthony (absolutely on a mission) is actually building a psycho 2JZ-TT in a full chassis hilux ute. Should be awesome.
Adrian
Driven (very well) by Dom Rigoli.
:confused:LOL its an auto being driven in a straight line...:(
Cant help myself:)
Good times posted for the Skylines, the all silver R32 (I think it was two.06l seemed to be having troubles.:P)
Tthe day itslef was a bit disappointing. If it wasnt for the VW brigade it would of been pretty quiet:(
I think the Cabin guys need to somehow incorporate their series with the wider state or national series...as the number and quality of cars just wasnt there...
That said not trying to take away from the guys that ran...good work for giving it a punt. :D
I should have gone true drag style and given my keys to someone else to drive my car to see what times it can knock out...lol cheap shot No.2:)
I have to agree. seeing a whole heap of cars running 20 sec and 15 sec quarter miles was not very impressive. some nice cars though, and congrats to Adrian. great run mate. very nice :P that mazda really hurt my eardrums...
good to see Paul out in the GTR. looked very nice, but didn't quite get the 10 you were after :D
Roy would have raced but word is he was scared of Adrians RB25 with only his lil ol RB20 to go against it with... :(
Meh, on low boost i run 2mph slower, he got noth'n:)
that's the spirit. talk it up baby!
I fully expect to see you at the next meet :D
as a wise man once said: "don't be weak sauce".
Good to see a few Skylines out there punching in some good times today - well done 2rismo on the PB although I couldn't hear your car running next to that RX7 - damm that thing was loud! Good work to everyone else who was running as well :D
I have to agree that the event itself was a bit of a let down and it also plainly highlighted some of the inadequacies of DYO racing. To think a stock shitbox lancer running constant +18 sec runs could make it to the ET2 final is an absolute joke. There should be some sort of 'qualifying time' to make it to the elimations at the very least.
is this car entered in "street car of the year"?...looks like no points for the drag component of the scoring for all (and that includes Dominic, TOF-55T) competitors who do not comply with the ANDRA technical specifications, that have previously ran a 10sec pass.
they all got to race for SCOTY today early in the morning and as for the ANDRA rule all i have to say is...
bwaahhhahahahahahahahahahahahahaha
brians MR WRX has run 10.9 twice and they dont make him put a cage they just let him run again and again and again.
TOF55T has a cage
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
