  • Replies 1.8k
Posted Images
So are you saying that the new design reduces lag after a gear change? I've been noticing lag on changes lately...and I dislike it a lot :)
It could probably be tuned out, but if the hole in the boost controller isn't helping, I might get the newer 1...
have you got the hole in yours?
as far as i know, the hole should actually reduce lag on gear changes.
i'm feeling the lag too, but mine has no hole. i might put one in it.
Hey guys i was mucking around with my controller and i took the screw out and the ball and screw came out.
When i put it back together, does the ball bearing go in first then the spring, then the screw? or other way around?
cheers
cheers
ball, spring then tap
so these are standing the test of time.. no one has had no big problems with them as they age?
i set mine, and left it. hasnt deviated or played up at all. pretty damn good for the price.
Edited by Munkyb0y
sorry i havent read all 64 pages before maybe the first 10 or so but didnt find the answer. so just a few quick q's if anyone can help
1 - are these still available ?
2 - are they a boost controller that gets rid of the original solenoid in the r33 so u can run whatever boost your car is capable of?? (sorry 1st turbo car so not 100% familiar with the system)
thanks
the r32 guys run more boost, but as far as i've always known, 12psi is the limit on the R33 turbo...anymore is pushing it further than you may want to....and not sure they make any power past 12psi anyway...where's paul when you need him
Just for some more feedback,
I have scince bought a new car and ordered another one of these, the new one does not have a hole. In the process of tuning the car I was monitoring the boost.
I am running a sliding performance RB25 hiflow turbo on an RB20 pushing 230rwkw. The boost controller was set to 17psi. The controller held boost so well it looked like a flat line. it was as good as the EBC that came on the car when I bought it. Infact I took off the EBC and sold it for $350 as the turbotech did the same job for $30 and could be hidden in the enginge bay and there is no solanoid or electronics to fail.
Gotta love it.
well i just bought one for my r this morning will see how it goes when it arrives
well i fitted mine this arvo and it works a treat set @ 1 bar i can feel the difference compared to my old grid ebc whick only worked intermittantly car is way more responsive now boost comes on a lot erlierand stays full boost til 7400 then drops down 0.1 bar
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
