firstly you are correct the stock heatshielding wont fit and anyway they deteriorate over time and start to rust and rattle. most people I think install a/m pipes as is. but when my friend and I both bought 3inch front pipes for our GTI-Rs he installed his as it came. the amount of heat that was radiated up through the floor was quite noticeable. I wrapped mine with heat wrap, then painted the wrap with flameproof high temp paint. no heat came up through the floor :D
can't speak for a GTR though, it probably wont be a problem on a light tune car.
  • Replies 72
I bought the Trust / Greddy Front / dump pipe combo....
Would'nt bother fitting the factory heat sheilds again for reasons mentioned above...plus they ruin my new exhausts good looks :)
I've been told Turbo's have to be removed to fit the dumps ;)
So may as well upgrade while i'm there, as I don't want to do that job twice.
I put the sheilds back on mine, but the pipes I got are much more similar to the standard shape, just larger....only required some small work with the all purpose adjusting tool.
but yours looks like a very different shape, join is much further back, I'm pretty sure they wont fit
That tool wouldn't happen to have a handle with a large metal striking piece attached to the end would it... :D
Yes the turbos have to come off to fit the trust pipes, no I didn't wrap mine, but in hindsight would have HPC'd them.
Maybe when i upgrade the turbos I'll get them HPC'd. Can they coat a used pipe? I assume that they would just acid etch it to clean it or something...
Turbos have to be removed, so might as well fit some extractors as well hey?
Err..no New Turbos :P
BTW, whats the going rate on Standard RB26 Turbo's these days?
(They appear to be in perfect working order and dosnt appear to have any evidence of a boost controller fitted)
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
