I think its something along the lines of
"me and ma bros are gunna head down to telopea st to get some tabouly and chek out ma mates new fully sic skyline with tha new fully leather interior, man i got aboused on tha forums todayy man those west aussies dont know nuffin eh bro."
What u guys are missing is that his stock blow off valve is different from all the other stock blow off valves that have been manufactured in the past :thumbsup:
how about we all stop the ****ing bullshit and keep on topic ffs,
Rossco, after doing some reasearch on fluttering i have found general its a bad thing, i have a hks sqv bov and it does flutter, general under low speeds. A friend also has a sqv on his s15 and it also flutter under low speeds.
I know for a fact that one jap brand bov does make the fluttering noise, i think it may be blizt but i cant remember.
But before you go and change your bov, think about this for a second; once replacing the bov it will results in your afr going abit rich, and may results in the car becoming abit slower (i will have to dig up the thread but one wa member memtion what affect changing the stock bov had on 1/4mile time etc)
ohh ps. im not sure where stock bov are but i found that the s15 which had the bov just after his plenum (greddy) was able to get abit more flutter noise and before people say they arnt setup right well they are
OK.
Every VL where I live does it.
Its easy. Find ur Blow off valve, modded or stock. Pull out the vaccum line hooked to the BOV and put a screw in it to block it off- it must be sealed completetly or there is a vaccum leak. That or run NO blow off valve at all.
Then. Make sure you have a Aftermarket cooler.
Then listen to the masssive CHO CHOC CHOC CHO VL style flutter. Its just common in VLs cos there too poor to fit a BOV/too dumb to put one in.
Its also known as DOSE! Its a favourite with the Chapel Street VL crew round here, u hear them flog it and let go. I must say thought it sounds pretty cool, but
a. its illegal
b. it attracts unwanted attention
c. It scares old people/kids/animals
d. It makes the compressor blades slow down, so not a performance mod
e. the guys that have it act like heros, but there just displaying there ignorance.
My suggestion is, run a aftermarket BOV with a harder tension, you will get a nice crisp flutter at low revs and clean pstchhhhhh at higher. I personally used a turbosmart V Port II on my old skyline and it had a great, non annoying noise.
I had massive flutter when the piston in my bov seized (no not a pisstake- the cheaper aus made ones seem to rely on blow by oil to stay lubricated). Recipe is big turbo/boost, no bov and pod. Sounded cool for about 5minutes after which it becomes ****ing annoying. I had around ten people ask me what type of bov I had when I took the shitter to the drags.... simple answer: a broken one!
a. its illegal
just on these two.
Dependingf what model car it is legal to have run no BOV
And you only notice the performance side of it in a manual, something to keep in mind... the autos just keep pumping along like most of the VL's here in Mexico :rolleyes:
R31Nismoid.
Yes the VLs dont need it so its legal, but this is SAU so for the budding SAU enthusiast that wants it on his skyline, it is illegal.
Excellent point made about the autos, It does seem actually that most of them that have the big flutter are automatic anyway so I suppose it shouldnt affect there straight line performance. Good on them.Hate to be going up some twistys though up a hill when you have to be on/off the throttle. :burnout:
']ohh ps. im not sure where stock bov are but i found that the s15 which had the bov just after his plenum (greddy) was able to get abit more flutter noise and before people say they arnt setup right well they are
Just after his plenum? So after his throttle body? Of course he was able to get more flutter noise as it sounds like the setup is completely wrong.
A BOV is there to vent off excess boosted air when the throttle has been closed. If it's on the other side of the throttle it can't vent anything.
']how about we all stop the ****ing bullshit and keep on topic ffs,
Brand is irrelevant. The actual tightness of the spring is all that matters.
just go out and buy ur self GReddy type s BOV and tighten the tension screw, it will flutter like a mother F***er, at lowish revs, and at high revs it will just make the PSHHT noise. thats wat ive got on mine and man does it sound crazy!!
this setup is normal in s1x type cars, i have seen it just not in my mates s15 but also in s14
The only time my stock BOV "flutters" is when i crank my EBC to about a bar, let it spool up from low revs, then release it before it gets a chance to use the boost (ie, change gears around 4K). It's not the BOV as people have correctly mentioned though rather reverberation through the turbo charger. Not a good thing.
Also, mass_iv is 100% correct, tighten the spring on any aftermarket BOV and it will flutter like a bitch at low revs.
P.S. Mikey, it's not after the plenum/throttle body, ie, not after the air is used, but it is that side of the engine bay on a separate pipe but still part of the pipe that runs to the plenum after the cooler. :P
do a search mate this topic being covered more than enough times...
lazy asses need to use the search option
I wouldnt call it being lazy.
It's obvioulsy a topic ppl like to discuss (30+ threads in this one alone), regardless of how may times it's been covered.
If it's annoying you that much, dont read it.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
