I've heard that some RS Liberty owners drill holes in their air boxes, or maybe it was their air filters? :confused:
Could I do this on an R32 to increase air into the box?
Also, are the standard air boxes better than a pod on an R32? I remember seeing somewhere once that someone recommended leaving the panel filter in. Is this baloney?
Cheers! :)
https://www.sau.com.au/forums/topic/7465-drilling-holes-in-air-box/
What a load of baloney!
Leave the standard air box standard. Otherwise you are pulling hot air into the engine, and hot air in the intake leads to detonation. Even more so when you rip out the airbox and replace it with a pod filter. It gets only hot air then.
What I did with mine was to remove the stupid little duct that feeds air from the front of the car to the airbox (it runs under the LH headlamp). Replace that with a piece of 3" flexible tube that drops down behind the headlight into the area just in front of the normal IC location.
Let Subaru owners drill holes in their filters, but I don't want to ingest anything bigger than a bacterium into my engine.
Guest Boxhead
then here is my question, on a turbo car, why shoudl it matter where the air is coming from, if its going through an intercooler?
surely if you have a nice big front mount that shouldnt make a difference.. :S
just make a partition if you put a pod on, and make a cold air intake..
Cheers! :D
I used my dremel cutting tool to cut a hole in the front facing panel. I have the K&N panel replacement filter.
Boxhead : it matters a great deal if you are sucking hot air. On the dyno you will see the power drop across the rev range without a cold air partition.
Follow the math:
Colder air = Better everything
If the intercooler is dropping the inlet air-temp 20 degrees C, wouldn't you rather have the temp drop from 40 to 20 than from 70 to 50?
Makes sense to me. I have a digital inlet air temp/ambient air temp and can definitely feel and SHOW the difference a hot day makes. So hot engine bay air is bad, m'kay...
:D
Hey JimiH
Forget the holes in your airbox those days are gone! the standard scoop is better flow than that,
Pod and partition like the other guys said.
The hotter the air in the hotter the intercooler temp will be as a certain intercooler might drop 30degrees rather than keep the temp at say 30 odd..
If I make up a big box out of tin, and then rivet the whole thing together, and contain a pod filter inside it, and then feed the cold air into the front of this tin box, will this work ok?
Is tin good for keeping hot air out?
Or should I insulate the inside of the box somehow?
Cheers!
Apparently, with the R31 at least, the airbox design is really crappy (there is a comparison article somewhere) and chokes proper airflow to the engine. I'd say that carries across into any standard R32, R33, etc. Anything is going to be better than the standard thing, even if it slightly hotter air. Its gotta be volume and coldness of the air - they are the two goals.
But colder air is of course better if you want to spend the money/effort riging up a front intake to take directly from outside. Make sure its well insulated as well or you're still going to have the problem of the pipe in turn heating the air from the engine bay.
you know that silver air conditioning tubing ..... could you cut that open to give silver sheets, and then line the tin on the inside of the cold air box, or maybe put it on the outside?
Just a bit extra to keep the heat out?
Or thermowrap the box?
correct me if i'm wrong, but aren't those aircon pipes for keeping the cold inside getting out, and not the other way around ?
i thought those mats (thin, blue one side, silver the other) they use in wood-framed 2 storey houses would be the stuff you're after.... keep the HEAT OUT ? not cold IN ?
Or am I dribbling faeces again ? anyone ?
if so, my gf works at an aircon place.... free ducting for all!
Strich9ine,
If a pipe can keep cold getting out then it will stop hot getting in. The pipes are reflective, therefore stopping heat transfer via radiative heating. A custom airbox with a cold air supply feed is a good idea, you can make the box out of whatever, aluminum/carbonfibre etc, but it is worth insulating the inside to stop the heat from the metal warming the intake air.
In a factory airbox I wouldn't bother with the extra insulation, the airbox is made of plastic and therefore doesn't transfer that heat very well, but at the same time it can't hurt, so why not.
See'ya:burnout:
Maybe you could line the inside of the box with the air con stuff, and then put the blue wood building stuff on the outside, and that would keep all cold air in and hot air out!
sweet! :D
now .... where's this air con place ur gf works at kym .... :lol: :rolleyes: :lol:
I'll be looking at getting a POD early next year hey, and I'll need some of that reflective aircon stuff... when I grab some for me I'm sure I could hook you up with some hey :D i'll see how it goes..
....gotta actually have a car in my possesion first hey!
hahahaha :lol: Kym :rolleyes:
how good is induction noise! :rolleyes:
I think I'll get a K&N pod, and make a nice box up for it with some heat resistant stuff ... that'd be swweeeeet if you could find me some offcuts as well :rolleyes:
cheers dood! :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
