yeah I do advertisements, I design logos and corporate id's, posters, signage, short animations, web pages all types of stuff just imagine anything that need to be layed out to be printed with type a Graphic Designer usually designs, whether its good or not is a totally different matter!!haha
I'm a tiler
Hi Guys,
I am a Stagea owner, in Canberra. By trade a fitter and turner, by profession Mech/Elec Engineer - and no I have deliberately avoided getting my ticket to be certified for engineering modifications. Sorry guys. But I do own a business (tyres) which is an authorised inspection station and does general mechanical repairs and limited modifications.
Anyway, remember that honest advice will cost you nothing and I will help out where I can.
Regards,
Marc2
ps If some memebers have assumed this to be a plug for the business then I apologize in advance for the mis interpretation.
dude who cares the amount of advertising that some of the canberra peeps give is nothing compared to that little plug :) eg integra automotive and trojan haha
lol southern x club. haha. FREE PISS ON ANDREW!!!!! hehe jks
yeah i'm at domayne so anything tv/stereo/whitegoods/video (not still) cameras, lemme know. was a car audio s1ut in the past so hit me up about any of that stuff too if you wanna know anything.
david
Awwww now he pipes up...or is that I should have kept reading this thread.
Anywho I just bought the new LG 42" plasma on Monday night..... and I assume that it was your R32 GTR parked @ Domayne on Saturday :-)
Brad
Brad
haha yes well that is what i do. and yes i could've saved you some money. and yes that was my gtr out the front.
next time!!
hehe
d
booyah! so we now have a real estate agent and lawyer on the local forums, now all we need is a used car salesman and everyone can hate us collectively!!! haha i'll edit the main post to include the last 2.
And a parking inspector! :chairshot
Well I'm a trainee Billionaire so come see me for your R35 GTR in a couple o years :Pimp2:
When I’m not training I work for a commercial broadcaster who has their hands in TV, Radio and Telecoms. I basically manage the operations of their networks in Oz and Tazzie.
Marc2, whats the name of your tyre store....the whole idea of this thread is to plug your businesses and services.
The thread was designed purely for this reason, If another member can use that service then its a win/win for both parties.
I knew i could be of a huge help to members with answering property questions and giving advice, and with the ammount of members we have here, if eventually one of them knows of a friend who's selling, then thats also an opportunity for me to offer my expertise.
im not as dumb as i look ;@)
Hi Veilside R33,
Sorry I missed the post yesterday. I own the Discount Tyre Service stores at Belconnen and Gungahlin. I tend to spend most of my time at Belconnen.
If you, or any one, requires any assistance etc ring me (6251 5977).
It is best to speak with me direct.
Regards,
Marc
Hi Veilside R33,
Regards,
Marc
I can really vouch for the guys at Discount Tyre Service in Belconnen. I had my roadworthy done there a couple o weeks ago (White R33). It failed first time due to turbo timer, faulty reverse sensor & boost controller (hey i didn’t know lol). My shifts at work stuffed me round and I rocked up the second time on the last day of the 2 weeks I had to fix it. The guys raced down & purchased a new reverse sensor, fitted it and completed the compliance that arvo.
They did the work with smiles & I know I'll be back for new tyres when the time arrises.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
