Just thought this thread had to come along sooner or later...
Drifting,
What car do you drift with?
What mods you got?
How have you set it up?
Which track is your favourite drifting track?
Got some GT4 driftin pics?
Now as for me, in the fieild of drifting on this game, I kinda suck, ok, I really suck. I wanna set up my Stagea 260rs up for drifting, can someone tell me how to set this car up for drifting? Some settings?
Cheers,
Chris
https://www.sau.com.au/forums/topic/75093-gt4-drifting-thread/
i use my s5 white garage tuned rx7 that i won with the different coloured front and back rims...lol didnt need to do much to set it up, just tweeked the suspension setup and bought variable lsd.
fav track to drift on is the suzuka mini track, i can do perfect high speed drift off the straight into the first corner and continue the drift onto the second one..and so on. i just do a couple laps and then sit back and watch the replay:D
have tried wackin in a bigger turbo but that just messed the cars balance up. also found that if you drift properly on that track you can get the same times or faster than if you drove normally.
Cheers,
Chris
"original" parts from tuning houses are good, esp the original suspension upgrades, as they are very stiff. and don't require alot of setup for drift.... ohh yeah, and turn of ASM & TC. Also if you want a fast dori racer then the "original" or stage 5 turbo is good as it has a bucket load of low RPM pulling power.
I find the best is my 32gtst. Spring rates are around 13-14 and sway bars at level 6. Turbo is stage 4 or so oh and i give it heaps of initial torque on the adjustable lsd. The only probelm with the game is the steering is too slow, you cant change direction at the wheels fast enough. My fav. track is midfield, with its long sweeping bends you can carry some serious speed through those corners.
I played a bit of GT4 for the first time yesterday, and i was trying to drift the D1 4 door R34, it was almost impossible, i dont think i pulled off 1 good drift. you guys have got skill if you can get the hang of it
Drifting,
What mods you got?
Cheers,
Chris
Pics eh..... pretty shit drfit but anyway
I hate to admit it but my fav car for drifting is the Lancia Stratos with full tune, etc on the track in Monaco ( can't remember the track name ). Before you throw rocks at me, spend an hour, buy and try the car ( if you've got a couple of extra credits to play around with ).
Turn it into a corner at speed, lift the off the gas drop down a gear and re-apply gas and there you have it.....instant drift :cheers: Soooooooo much fun !!!!!
You should play sega rally on saturn then. r0x0r
I like using the Bluebird SSS-X, everything modified to the max except leave standard gearbox and use the crappiest of the free tyres.
Suspension setup:
6.2kg front, 5.6kg rear.
4.5" camber front and 3" rear.
ride height low as possible.
It's a brilliant setup on tsukuba, and the car has a great balance.
gone the dori style with my favourite Toyota, a JZX 100 chaser,
original parts,
camber on 3.5-3 respectively
6kg front and back
sh!test of the sh!t economy tyres.
no aids (a must)
love the autum ring, nice quick tight corners to throw the fat mumma around. n she loves it
Sega rally on Saturn rocked! I still got it somewhere.
Sega what ?!?! :confused:
( Sorry, this PS2 is the first game station I've owned )
BTW How do you take those pics of the cars during the replays on PS2 ??
Sega Rally on Sega Saturn (released 1995)
Save your replay then play it in replay theatre, press select while its playing to take pics. Or just do a photo drive.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
