OK guys, i've been given an oppurtunity to get what i think is a pretty cheap RB31DET bottom end (block).
What i'm asking is the maximum any of you guys would pay for this, here are the specs:
-VL RB30 NA Block, deck has been honed and the bores have been made 20 thou oversize for the bigger pistons (3.1Litre)
-Hypa-tech pistons brand new and 20 thou over size (makes it a 3060cc I believe) Their semi-forged and ceramic coated
-Rods are standard but have been shot peened and balanced to make them all the same weight etc.
-Crank is standard but has been ground and balanced.
-Block has been grub screwed for strength.
-Has all new Welch plugs etc and all new bearings
-All the oil and water galleries have been cleaned and the oil galleries have been modified for better use for turbo's? (not sure on that one either)
-ALL it needs is an oil pump, water pump, sump and head obviously which i already have to complete the bottom end, everything is together and has all been done by a reputable engine builder here in Adelaide.
So my question is how much would you pay and any other comments are more than welcome!
theres about $700 worth of machining in preping a new engine on a rb30, and buy the sounds of it around $700 in parts assuming they are only standard type pistons... So I wouldn't pay much more than $1200.
they will be standard cast pistons, only new. grub screws in the crank are for the rod lubricating oil journals on the big end, nissan drilled big long holes to connect them and then bashed aluminium plugs in there to plug em up so oil wouldn't leak out (duh) and lose pressure. after a lot of k's they can become loose so you drill em out, tap it and put a 1/4" grub screw in there. stake it and you're done!
it sounds exactly the same as my block, you're looking at $500-$700 of prep work by a machine shop and up to a grand again for rebuild parts (rings, bearings, pistons, seals etc) so i wouldn't pay more than $1300 for it.
thanks guys. thats what i wanted to hear. the guy has offered me it for $750 so i'm going to go pick it up Tuesday
And by the way the pistons are 'HYPER TECH'
think i've heard of them before!
There is a brand of pistons called Hypatec, they are hypereutectic pistons made by Right Way Piston Co. in Taiwan. theyre a nice piston but from what I know they dont make anything forged for the RB. There is a Hypatec liquid forged piston that is excellent but not available from what I know for an RB engine at all. They are made by pouring the liquid alloy into the die and forging it once it starts to solidify. This is the same way that Toyotas forged pistons are made and when you see some 1000hp-ish 2jz's they are awfully strong.
I've seen coated pistons for the RB30ET but not for the n/a engine. It's actually an anodising they use. Be careful if it has a slightly dished piston rather than a dome as you will have way to low compression.
It is a good buy, just depends if it fits your needs.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
