Cam Gear & Dyno Tuning Results @ Croydon Racing Development
I am extremely happy, it drives like a standard GTR @ 60kmh in 5th gear (1300rpm)
2nd gear breaks traction at all 4’s on shear acceleration J
Please refer to attached graph, this is my 4 wheel dyno tune figure by CRD on the 20th June (my birthday)…
THE CAM GEAR DEBACLE…now proven!
I was there from start to finish & saw the comparable difference.
The red line (on the graph) is tuned with cam gears at 0 degrees
The blue line (on the graph) is with tuned cam gears - keep in mind I do have the poncams…what a difference!
Jim has made an additional 100Nm without sacrificing top end delivery…
This proves that adjustable cam gears do make the difference & that Jims dyno tune has made a massive difference in torque!
Only the experienced guru’s of the industry are aware of this advantage.
I also had a long discussion about road tuning with Jim – he is of the opinion that you cannot simulate ‘load tuning’
i.e. load tuning at various rpm’s for a specified time period, where can you do this on the road & how can you road tune a car under load?
At the end of the day Jim has 15 years experience with GTR tuning & the experience alone is working with all facets such as drag, targa, circuit, national teams, race production class etc….who else in Australia works alongside with top tuners in Japan & national racing teams? I guess this is why he is the busiest workshop in Australia, just have a look at the number of performance cars he has in his workshop & yard (over 30 cars).
YOU PAY FOR WHAT YOU GET – yes other tuners are cheaper but you will not reach the maximum potential if cam gears are not adjusted to suit the setup.
The way I see it, if you are prepared to spend over 10k on an engine then investing another $400 additional for a proper tune is the way to go…
Question: would you pay the small difference in tuning for an extra 100Nm of torque?
I am not here to convince you or sell CRD but I did want to share my experience with you as I am extremely happy with the outcome.
Thank you Jim ;)
Regards,
Marko
0404 884 876
  • Replies 81
Posted Images
yeah, I was curious about that too. my guess is boost controll. certainly a very nice number. Very sharp curve. BIG fat top end, but the bottom end seems a little dissapointing to me. I would personally like more 'area under the cruve', but i don't think that's a reflection on CRD more a turbo choice thing. Do you have a graph with Y axis in RPM instead of speed? if so could you post it up?
enjoy mate ;)
Agreed, but you'd be a miracle worker to get Jim to tune a GTR for $400.
$500 is what he normally charges just to dial-in cam gears, let alone TUNE the GTR.
A basic GTR tune starts at $800 and rapidly increases from there.
I have never stepped foot in that workshop without being slapped with a bill LESS than $1000.
I spoke to them today they said $350-750 for a full tune :) who knows but..
Doing a power run on Saterday morning to see what this biatch is making :Pimp2:
Merli,
Im with blk180....he is saying that it is only an additional $400 or so in comparison to most tuners who charge anywhere b/w 500-700 etc...
Im in agreeance with you marko....fantatsic results...wow pretty impressive!!! Im amazed at the difference with the cam adjustment...thats worth the extra $$ to me!!
I'll bet you $50 that he wants to change the oil, and spark plugs before tuning it.
And it seems the more power a GTR makes, the more he charges... Presumably because there's more liability and less room for error with highly-strung GTR engines.
Understandable I guess, but it gets old when you're told "$350-750" and then get slapped in the face with a $1500 bill.
Anyway, good luck, and you have to come to the next dinner and let me take it for a spin... I'm having major power withdrawls :P
P.S. Have you put on an oil cooler yet? :squint:
Anyway, good luck, and you have to come to the next dinner and let me take it for a spin... I'm having major power withdrawls :)
I'll come to this months dinner..
I was going to get an Oil cooler but after 4 new so3's + rego i have no bling bling left :P
There was a fair amount of meat left on those tyres?!?!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
