The recommended nissan oil grade is - 7.5W30 I do believe (off the top of my head, you can check the service manual for this) Speaking to nissan guys - they recommend either 10W40 or 5W30.. if your driving it hard - think a couple of the guys on here recommend 10W40.. plenty of posts on it - do a search - but advanced - and make it all topics including those >6 months..
default search is newer than 6 months - you miss alot..
My mechanic recommend i use a 10w-40 oil. It sound too thin for me... does anyone use this grade(rb25det)
Yep...
And after the rebuild and still running in I was using it (after running in oil) Motul Turbolight as it is semi.
Now cause of the moly rings I go full synthetic, Pennzoil as I get it almost for free and its the shiz, better than when I used Mobil 1 etc.
Oh and use the search this subject has the most threads on it I reckon :soap:
use what they use in the JGTC MOTUL 8100 turbolite it was developed for the rb engines.
no offence mate, but I don't know where you heard that. no way would ANY JGTC team use 'turbo light' when motul make much higher spec, proper synthetic oils. as for it being 'developed for RB engines' i must say i do detect a hint of bullshit in that claim too.
BTW I'm not knocking motul oils (I use motul oil).
I'm sure whatever they put in the car they probably called "Turbolight": the fact its got the same product family name doesn't mean its the same stuff.
You know the Shell Helix in Ferrari F1 cars is the same stuff in my local servo. Honest. They say so on the ad :)
Lucien.
You Guys Are All Mad!!!!! (and Get Paid Far Too Much!!!)  Valvoline Xld 10-50 Is The Go.....(get It At Kmart For Less Than $15 For 5 Litres). Change It & The Oil Filter Every 5000klm & The Engine & Turbo Will Last For 300,000 Klms........
You run a mineral based oil? Ok then......
Lucien.
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
