Hey all, just got a few questions about bodykits for the ever popular R32 Gts-t :D
Ive currently got the stockest of the stock frontbar for my 32 and im looking to get a bodykit when i eventually respray and get all the blemishes fixed. Ive seen the Type-M factory bodykit which has the side skirts, rear quarts and quite a beasty frontbar.
Here's the questions!
1. Where in Australia can I get my hands on the Type-M frontbar Im looking for?? (hopefully a new one made in australia like the GTR knock-offs that are everywhere, but I'm willing to buy one off one of you guys if ur selling!)
2. Does anyone know how easy it is to fit a FMIC into one of these Type M frontbars?? Does it have enough room to fit a decent sized one?? (eg Trust)
2. Should I just give up on the Type M frontbar and lash out on a GTR one as there would be more room for the FMIC in the GTR frontbar??
My main reasons for choosing the Type M bodykit is the fact its not as low (less bumps and scrapes on low lying objects) and Im not really looking to make my Gts-t look like a GTR.
All advice apreciated greatly!
https://www.sau.com.au/forums/topic/82007-r32-type-m-bodykit/
A few people I know that have GTR front bars on their 32's still needed to chop the bars a little bit to fit the pipping for the FMIC. Not sure about room for the Type M front bar, but im sure you would need to do a fair bit of chopping to fit in a FMIC
cheers for the info sl!m, i hope there wouldnt be too much more cutting involved coz the main difference between the GTR and Type-M frontbars is the lip at the bottom, the Type-M being without it of course.
anyone else with other suggestions??
well actually the "type-m" bar is more of a flat bar, if you look at it from the side.. example (i think)
whereas the "non type-m" bar (or I think the earlier ones) slope in a lot more at the bottom, which is what causes the problems with the fmic fit.
Do you see what I mean?
cheers for the pics predator, yeah thats definately the type-m bar at the top. i see what u mean about the type-m bar being flatter at the front, hopefully that'll provide enough room for a decent sized FMIC. i reckon ill give the type-m bar a try rather than give up and go for the GTR front, what can i say i do like the gts-t look :huh: if i cant souce one in adelaide or even australia, ill check to see if they have a chain of "u-pull-it" type places in japan and raid them for cheap body parts!
Wouldnt a wrecker be a good place to start? No one really wants them and the come in a fair bit on half cuts, so you should be able to get a good original (plastic not crappy fibreglass) Type-M front bar pretty cheap.
But remember the Type-M front bar was an option even on the Type-M so not all of them will have the bar you are after (the one with the little vents along the bottom of the lip.)
All R32 GTS-T's come standard with the type m options ie. larger brakes, different steering wheel etc. etc. The first of Predator's picture is the factory option aero kit which is present on my car.
As for putting a FMIC in my front bar it will fit in easily as long as the centre support bar (A bar which sits directly in the middle) is cut out. Even type M bars can fit large intercoolers in pretty easily. I have a mate who just installed a 100mm thick hybrid copy intercooler into his type m front bar which only just fits in.
thanks for the info guys, im glad to hear someones actually installed a FMIC in the bar im looking for with some success :) i reckon theres a few wreckers in adelaide i'll be able to search so all is well. itll be a while till i can actually afford all this of course but now im armed with knowledge. cheers everyone!
My type-M has the front bar from the middle picture. While it doesn't have the lip at the bottom, it's got a funky retractable on which comes down automatically at high speeds or you can control it from the dash. If you'd be interested in that i'll be pulling it off soon for a custom kit.
wow... how hot is that car!!.. that car is an 89' model just for the record.
Also, why would you need to cut holes in the GTR front bar for a FMIC? I thought it came stock with a FMIC... or is this for a larger FMIC?
I've a '92 Model Type-M and in terms of fitting an intercooler some modifications would be required to fit a FMIC. I've ended up getting an R32 GTS-t specific Blitz kit with piping and managed to get it all fitted nicely.
the only thing I realised was the when I went to put the front bar back on. It didn't fit. so for the centre intake cowling I had to shave back about 4 centimetres of plastic including cutting out the middle support bit to fit it in there.
I also found some brochures online for the R32 series and found that the Type-M front bar and side skirts your mentioning and see on the photos were actually Nissan factory optional extras called the Style Tuning Kit.
Anyways I have a look!
nice work Jenius.... hehe, i also stumbled across something in the DIY section of this site, it looks like a guy has gone through one of those brochures and scanned every R32 Gts-t option and posted it with descriptions, all R32 owners should take a look!! its nuts
http://www.skylinesaustralia.com/forums/in...showtopic=48934
I disagree with you Baz.
From Predator's website you can see Gordon swapped his 'front stock "non type-m" single pot crappers (which the car came with) to the "type-m" 4 pot brakes'.
Non-Type M's have a steering wheel very similar to an S13 and have a plastic gearknob. I'm pretty sure the rims are also different. There was a recent thread where a guy had two GTSt's to choose from. One was a black standard GTSt and the other a silver Type M.
Mark
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
