The RDA954's fit Series 2 AWD Stag calipers without machining down the OD (no rubbing or clearance issues). We have fitted them to one car already and will fit them to my Stag soon.
did the 954S fit your Stag with no issues?
Guys, I know a couple of people have had a positive experience with these rotors on S2 RS-Four V *without* machining the OD down, but my experience was different... I discovered serious rubbing/binding after fitting these rotors without machining down the outside diameter; there was no apparent binding after fitting them and checking the sliding section of the caliper for clearance (where it gets closest, in the middle) but at about a K or so's low speed driving down the street I had smoke billowing out of the front wheels. It definitely needs some metal removed from the OD; I'm going to have 3mm taken off to make it match the original rotors.
Also, has anybody else who's fitted these noticed that the original rotors are ~37mm thick (by my measurement) but the RDA's are ~33mm thick? Plus the minimum thickness on the original rotors is marked as 26mm, while the new ones are marked as 22mm. This means a difference in piston travel of 4mm which may by significant. At the very least, it approximately half-emptied my master cylinder reservoir once they were on and the pistons were in the new location.
I've now gone back to the original rotors, again. And I'll have to get the new ones machined, again. But one day, one day I will fit new rotors to this car...
what is difference if any between S1 and S2 brakes? ie rotor size
Basically rotor size and offset (series 1 is smaller). Easier to find series 1 replacements; I think you don't have to stuff about getting series 1 rotors machined to fit. Check the first post of this thread for series 1 rotor part numbers.
thanks for the update :)
more to think about :)
are the RS Four S rotors the same as RS Four V etc.?
If your thinking of upgrading from S1 to S2 Stagea.
Just go to R33 Skyline brakes, as they are easier to get discs and pads for and better performance.
As we can get Rotor`s & Pad`s for S2 for UNDER $300 i call that Cheap, you have much more about then most think,you have a PAD that is 157 mm long it`s much the same as have smaller pad`s with extra clamping pressure ,so there about same,S2 brake which every one like`s to BAG`s are ok if you don`t think your in a SKYLINE,cheer`s Chuckie.
found direct fit front pads for s2 stagea EBC's part number DP1671 was 95 trade price, 125 retail i think
Yep, that number's correct. Our price on the DP1671 is $86.
But you're only talking about EBC Black, they're a pretty ordinary street pad at the best of times, and NOTHING in the way of performance.
If you're after something that's going to pull the car up a bit better than stock, then we've got both QFM options on the shelf.
- High Performance Street, QFM HPX, Bendix Ultimate equivalent, $119 for the set.
- Street/Track, QFM A1RM, Ferodo DS2500 equivalent, $179 for the set.
In comparison EBC Green are $195, so the QFM are far and away the best value for money S2 pads!
Will R32 GTR brakes work on an M35? I know I can pretty much use R34 brakes but unsure about 32's.
perfect fit. You need to get R32 rotors to match.
And grind a small piece back for clearance of the rotor.
That is what I have on my M35.
Cheers
Andy
Just put the black stuff in my car and they pull up good even when cold $70 :D
good luck pulling up the green stuff without warming them up first.
G`Day why come here & BAG another BRAND :) ,NO NEED TO DO THAT ,really ,now i have EBC BLACK & have had no worries,& as your PRODUCT is like nearly X2 the cost of the EBC ,i don`t see that as GOOD VALUE :) ,
this is not the PLACE TO BAG other Product`s ,+ EBC have DROP PRICE of pad`s world wide,
Cheer`s Chuckie.
Get a grip Chuckie... I wasn't bagging EBC Black, and indeed we're a premium RDA dealer, and do quite a large volume of them... but if you think EBC Black are a performance pad by any stretch of the imagination you're sadly very mistaken. Nothing I said in my post wasn't true, and EBC Black are nothing more than an ordinary street pad. Compare equivalent performance pads to the QFM HPX or A1RM, and then come and tell me they're not good value...
... and if you read the post above yours clearly we're not the only ones who think so.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
