Nathan pull your pants up and zipper round front. Half the reason I was going is uncle Nathan was going out.
Also check with the boss before putting your hand up for motorsports events is always a good idea. I must train you up. I live with four bossy women and learned lots about this. I am sure I will find someone to take your place. Do accept zeds with money?
Pete there is more to motorsport than beer and burning rubber.
Benm you are motorsports s**t and if there was a prize for it you win by far, cya out there.
  • Replies 173
bugger! Nath, i would have taken your spot in a second, but since i decided not to go to this one, i'm now booked in to be down at goulburn at wakefield for fri, sat and sun. bummer.
please don't sell your spot to john though, he'll just bring more boats.....
Times
Yes Duncan I know I can't run less than 15 psi so?  Weight you mean you have not lightened your car?  You can do that and or add weight were you want.  I might drag an anchor in the boat is that acceptable. By the way I did a 48.27 with a tyre that kept goingflat and 11 and 12 psi flat and eended up rolling off the rim. If conditions are good I will do a 47 on this day. I will be there by the way I contacted Aaron direct and paid and locked and loaded. How could I miss this sounds like it will be a big Skyline day how many going anyway?  How many paid not just  saying they are going.  Lets hope for not too hot weather.
Duncan you going?
Mark Hawkins going?
GTR Jason going could be a showdown?
Paul D or is he straight line only man now?
Probably all get done by those irritatingly fast little noisy things anyway.
Paul D will never be a straight line only man...love to come but we have put a lot of time in getting the car right for the next round of the Aust Champs and i'd hate to fu(k it up now. Can't wait to get back to Oran once this drag things over....i do miss the corners John.
I did check with the boss for the first date set not the second... my bad.
Tommyk took my spot, and Tom if it is raining GET OUT THERE!!!!!!!!!! atleast to see John try and tack his boat from port to starboard over the dogleg. :lol:
Luv that one Nathan. I also might put the anchor on board if wet so if I lose it over the dog leg I can throw it out in an emergency.
It would be a shame to have more zeds than Skylines on a Skyline day hey. Common guys get out from behind your keyboards and have a go. You would love to beat a zed shouldn't be too hard.
just you wait john! when i get you i will do a burnout on a tweed cardigan just to rub it in :P
now, someone please buy john one of those hats with the little piece of rope around them, that says "captain" on the front for christmas...
The minister for entertainment and finance has knocked back the application to attend a 9am - 1pm drive prior to a family event. I attempted go into aggressive negotiations only to be out voted by the back bench.
Sorry guys, Im a no go. Enjoy the day and keep the cars on the track and away from the walls and kitty litter.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
