  • Replies 98
It really has got to the point where a 13 second pass isn't anything to write home about. Flipping through this year's Bang for your Bucks issue of Motor magazine, no less than 6 cars ran in the 13s (HSV Clubsport, Subaru STi, Chrysler SRT6, Porsche Boxter S, Mitsubishi Evo VIII, Falcon XR8), with two others within a bees dick (HSV GTO 14.0, FPV F6 Typhoon 14.01). When there are this many stock standard vehicles running 13 second passes, it really loses it's impact.
I think for sure that 12's are the new 13's. And it won't be long before 12's just aren't that special anymore. The German's are already there - the BMW M5, Mercedes E55 and Audi RS6 all run 12's stock, and they're all big heavy sedans. How long before 11's are the norm?
Its very true that cars are getting faster these days but you come to a point where traction overcomes power. The difference between running a high 13 and a high 12 is about 10 car lengths, (think about it now). Are there any HSV cars or CSV cars running 12's with their huge power?
Traction is the key, thats why you can get midly modified GTR's running 11's,.
Mine runs 12.5 in street trim from a mild GTST. At the strip i had great traction, on the road i have no traction. I would be lucky to run a 13 on the road. Though lately i bought some good rubber RA1's and it has made all the difference to traction. I think with a bit more power, i could possibly run a 11.
having been a regular spectator at WSID, unless the car does a huge launch and/or wheelie, or runs 10's....
... or think that the water/burnout area is actually the starting line, do a burnout and continue straight past the starting tree, across the line and then not realise their is a hairpin at the end of the track and beach your car in the sand (as 2 cars did last week).
...not many people are interested.
I'm happy to say that I cracked a 12 with the Std turbo on my final run at WSID tonight :P;):D
ET: 12.993 @ 104.40mph (60" 1.777)
After so many 13.1's and 13.0', it was good to finally get there :)
Also ended up winning 3rd in the reaction time competition, so a bloody good night all round :)
i guess it depends who you hang around (as most people have said)
Im 18, and at my tafe; i get alot of people talking to me about cars and stuff, and to them 13's is fast but then again they dont really know about carsm dont understand the idea of supporting mods and think all u need is huge turbo with ahist load of boost.
im still tring to crack a 13's with my r33, god-dame rb20 turbo :( im only making 200-210rwhp if im lucky @ 12psi
I'm happy to say that I cracked a 12 with the Std turbo on my final run at WSID tonight :(:P:)
Also ended up winning 3rd in the reaction time competition, so a bloody good night all round :D
Well done, excelent time, welcome to the elusive 12 second stock turbo club!! What tyres are you running to get that 1.777 60'?? Did you dump it or ease out the clutch?
Congrats :( Weren't many cars there - how many runs did you get?
I got 7 runs in - definately a good night to be competing. There was a good representation of Skyline's - noticed a few GTR's (incl CYIFLY and Mik?) and the usual array of GTST's.
Thanks mate - it was a good feeling to finally get that 12 :P
I was using BF Goodrich drag radial tyres. I think I pretty much just dumped the clutch from 5000rpm on that last run and the tyres just hooked up perfectly. It was the best 60" I've ever done :)
Yeah a few GTR's about last night. Can't believe it was so quiet, maybe they all got scared because of how cold it was the previous week.
Thankgod a 20yo won that 'Miss Wicked Wednesday' comp, too many 16yo's. How hot did Monique look :(:P:)
I only saw one black R32 GTR (11.8), one white R33 GTR (11.9?) , and one white R34 [CYIFLY] which ran an 11.7, but I got ther late. Is Mik's the R33?
Mik did a few high 11's best been 11.7 and best mph 122 but he had some fuel problems .
I will be out there in a couple weeks ( when my clutch is run in ) to see what i can do .
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
