hey guys, need some help with regards to the inner clearence on a r32 gtst. I know how offsets work and all that jazz im just not sure wether i will foul the suspension or not! I currently have 17x9 +20 all round wit guards flared on rear so wheels sit maybe 10mm inside guard and front guards pumped so wheels sit pretty much flush on guards. Wheels im looking at are 18x10+35 rear.(will sit 27.5mm closer to suspension) and 18x9+35 front (15mm closer to suspension). Both front and back will sit inside the guard more than the 17s so my concern is the suspenion. Any help will be much appreciated...im looking at you nisskid! :cheers: cheers
Are 235/45/17 tyres OK on the stock R34 GT-T rims ? Standard is 225/45/17. I've used a calculator which says it will change reported speed by 1%, but will this fit fine on the rim and is there any benefit or downside ?
  • 3 weeks later...
hey guys, need some help with regards to the inner clearence on a r32 gtst. I know how offsets work and all that jazz im just not sure wether i will foul the suspension or not! I currently have 17x9 +20 all round wit guards flared on rear so wheels sit maybe 10mm inside guard and front guards pumped so wheels sit pretty much flush on guards. Wheels im looking at are 18x10+35 rear.(will sit 27.5mm closer to suspension) and 18x9+35 front (15mm closer to suspension). Both front and back will sit inside the guard more than the 17s so my concern is the suspenion. Any help will be much appreciated...im looking at you nisskid! :D cheers
hey mate, sorry didnt see this before haha, +35 with a 18x9 is cutting it very close on the front upper control arm, ive run quite a few 17x9 +30's on the front and theres only been a few mm of clearance. 18's will come up even closer once again, if you look at the angle of the control arm and how it sits ull see what i mean. also tyre size will play a big roll in this, obviously a bigger tyre u have less clearance, if it comes down to just the tyre fouling and not the rim, then maybe try something around a 225/40. if you are dead set on the wheels and dont mind running spacers then id grab them and make up mock spacers to see what size u need, then go buy a pair, ull probably only need some slip on 5mm's or something which cost shit all.
as far as the rear is concerned, once again ull be cutting it very close, but unlike the front, having a larger diametre wheel actually gives u more clearance funnily enough. if you look at the back ull see (depending on whether ur car has HICAS or not) u have a rear tie rod end for the HICAS which sits there, a 17" wheel around the 10" around the +35ish mark u will be coming bloody close if not already fouling on it. however an 18" sometimes will actually just clear this and u wont have any fouling issues there. ive heard of some people having this issue and some people not so id imagine it has something to do with the design of the barrel/rim as well as the diametre.
i wouldnt be worrying about the rears as much as if indeed the wheels didnt clear over the HICAS end, then it would be a matter of a spacer of maybe only a few mm thickness.
i cant remember, but i beleive the stock R34 rims are 17x7? yes u can go 235/45, as the rim has a fairly high offset im sure uve already realised that it sits in the guard a fair way, so there shouldnt be any fouling issues on the guard, and since going from a 225 to a 235 u should only expect the tyres to bulge out by 5mm each side (235-225=10mm, 10mm/2=5mm) so there shouldnt be any fouling issues on the inside either.
hey guys. I have a R34 GT-T and am looking at the NISMO LMGT4's. the sizes are:
18x8.5 offset +25
18x9.5 offset +30
Would these look weird on the car or would these be a good match?
Thanks for the help.
Jay
need your help guys. i got a set of wheels i like they are:
ROH DRIFT R's
front= 18* 9, offset +26, tread 234/40/18
rears= 18*10, offset +20, tread 265/35/18
will they fit?
thanks
18x8.5 offset +25
18x9.5 offset +30
Jay
they would be a nice fit, depending on the tyre and camber you will probably have to roll the guards on the rear and maybe the front if they arnt already.
hey nisskid. thanks for advice mate will keep it in mind next time.
I decided against the wheels as i dont want to be running spaces, and the fronts simply wouldnt fit with out them. :( thanks again dude.
no probs mate.
ROH DRIFT R's
will they fit?
thanks
fit what car?
if its a R33 GTS-t, u will have issues fitting them, to fit them with a minimal flare you'll need to stretch a tyre on both.
I had a look through this thread and can't find the info I'm after, so I was wondering if anyone can tell me the highest of the following sizes that could fit an R33 GTS-4 with 4-stud wheels without having to make any modifications. Ideally, I'd like to get 18x9.5, but after looking at my current 17x9s, it doesn't seem like theres much room left to go wider at the front. Thanks in advance to anyone who can help
17 x 9 (+35 offset)
17 x 9.5 (+18 offset)
18 x 9.5 (+35 offset)
18 x 9.5 (+18 offset)
This is where I'm getting the sizes from- Drifteks
Edited by jimnastic
  • 1 month later...
Hi Guys,
I'm wanting to get rid on the 17" on the skyline and upgrade to 18's..
What's the best dimensions to be running 18" on a R32 GT-R without needing any mods to factory guards? e.g. 18x9.0 +?? or 18x9.5 +??
Looking at a set of Rays Engineering GL 57 Pro with OPTIONAL TITANIUM LIP - but need the offsets to give to the suppliers to be able to get quotes for these..
Cheers,
Adrian
Does anyone know if 18x9.5 will fit on a gts-4? Sorry to ask again but I'd like to know soon so I can buy some new wheels. I'm just waiting to find out if they fit..
u can make it fit, depending on the tyre you run up front and the offset all around.
Hi Guys,
Cheers,
Adrian
depends how wide u want to go, id probably go a 18x9.5 +15 all round if it was me, but thats me, depends on what u want.
Hi Guys,
Cheers,
Adrian
Most People go 18x9.5 +22 on there R32s i have 18x10+18s on mine ans they are a little big but look tuff.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
