R32 GTST
18 by 9 +22 all round.
Lipped guards front and rear, -3 camber roughly front via camber arms and stock rear adjusted fully. Rubs very slightly on the rear, front is fine.
IMO the best fitment on a 32 without pumping guards.
I have a R32 gts-t and i'm looking at some ROTA Grids
I love the staggered look and they are cheaper so thats what im going for.
17 x 9 + 12
and
18 x 10 +15
Im 99% sure these would require some guard work to make fit? Do you think that a 10" on a standard gts-t guard?
Rota grids
18x9.5 +25 would this offset poke at the front on a r33 gtst?? I know +20 is fine for the rear but just mainly wondering about the front
[/quote
depends how low you want the car to be, a full steering lock might produce some rubbing and going up steep driveways unless theres a decent gap between tyre and guards, because the wheels and tyre dont tuck up under the guard anymore
be more practical to have 9inch wide or 8.5 on front and 30offset max, depending how much work you want to do with camber, rolling, suspension
would anyone know if an 18x9 +23 would fit on an r33 gts-t? Has rolled guards and coilovers. Help would be really appreciated.
Has adjustable coilovers with stock camber/control arms etc. was thinking 225-235/40 up front and 235-245/40 for the rears (rims dont have tires on)
im looking at 18x9.5+12 all round for R33 gts-t, can i do this on the standard guards?
Bare in mind i want to run a 245,255 or 265 tyre up front an 255 or 265 down back
also considering 18x10.5+15 all round, would these suit with front wide/pumped guards an pumped rear guards?
For 18x10.5 +15, you'd need a helluva of flare to fit the rims even with 255 or 265 all around.
Friend did it on his 32 GTST, 50mm pumping rears and 30-40mm front on GTR guards, to fit 10.5 +15 with 265/35 semi slicks look very tough.
hmmm sounds good, ive been looking at front an rear guards for some time now
now i know ill add rear guards to my shopping list too :thumbsup:
hi all i have an r32 4 door and have found my favorite wheels at the right price if 18x8 and 18x9 +30 and +31 offset will fit on my car cheers
Should fit right in.
Hay guys,
got an r33 that i'm putting 25mm rear guards on aswell as 20mm front fenders
so everyone says that a 9.5" rim with +30 if flush for the rear, so i'd take 20mm to get flush with the new guards yes? so a 9.5" +10 should be close to flush with new gaurds
i dont know a flush fitment for the front working off what i have now i'd say ( 8" rim +15-20) can someone please confirm :)
the rims i am gonna buy are Yokohama Advan RZ-DF
my question is will the follow fit flush for the wider front and rear guards:
front: 19 x 9 +25 then add a 15mm bolt-on spacer??
rear: 19 x 10.5 +25??
any help will be muchly appreciated
Hay guys,
hey im not sure but i think fronts will be a tight fit will also be very close.....hmm, i have 18by 9.5inch with 245 and it just scrubs slightly on front, with wider guards on which im selling, they are fine(15mm wider) rear seems to have a bit to spare with same width tyre and offset (30 all round)
so you will be pushing to limits i reckon...:whistling:
Hey guys,
I'm fairly new to this sort of stuff and I was just looking to find out some information in regards to wheel fitment for an R34 25GT Coupe. My car came with these 17" 6.5JJ wheels. I don't really want to go anything bigger than 17" but I want to get some wider wheels. What width could I go on the front and rear without having the wheels rub on the guards? Also, what offsets are best for an R34 25GT Coupe? Like, what range?
im running 18x9.5 +20 on the front of my 34 gtt and it only sticks out a bit.
with yours being +12, will stick out 8mm more, so with some camber it will tuck in & also depend on your ride height too.
but with 255/265 up front will scrub, best to get 235 or 245.
ill most likely run 245 up front on my 9.5".
Just wondering if 18x10 +15 with 225 tyres will fit on the rear of a gtst with only little lowering with coil overs no camber arms
Cheers
Chi
will stick out, unless you have camber arms to tuck em in, its gonna look silly.
18x9.5 +30~ will be fine without camber arms but it will generally camber in when you lower the car anyway.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
