Goes in to get some suspension fixes next week (replacement of worn bits mostly) and a wheel alignment so not sure if he'll keep things this way but it was 1 degree neg on the front. So may change.
Very happy with how it looks, the 10.5s finally fill the guards up! Not missing my little 9s!!
Running -2.5 in the old setup.
New setup running 17x9.5+18 with a 245/40, with probably about -1 degree... Very grippy!!!!
Thanks for the info Billy. BTW love the feature you had on Stance Nation a few months ago. Thumbs up to you dude!
Anyone fitted 18 x 10 + 15 on there 32 gtr? any photos? modifications required?
was thinking of putting 255's or do you guys reckon definately 265's.
Cheers,
Thanks
i just fitted 19x10 +15 on my 32 gtr... 245 tyres tho otherwise im sure there would be some major turn and scrub issues on the front. i am about to roll the rear cause it hits atm (car is quite low)
also about 2° degs of camber on the front & about 1.5° on the rear...
255 or 265 wont be much stretch at all as a 265 is recommended for a 10 from memory.
i had a 265/35 on a 10 was zero stretch
i was thinking tyre stretch may help with the guard, may not need rolling, although i do like the idea of running wider tyres
i run 265's on my 34gtr rims, they sit perfect and no scrub/rubbing at all (rear guards are not rolled)
maybe depending on how low it sits too would determine what size tyre to run on a 10" wide wheel?
hey guys though id ask my question here then make a new thread.
Just wanting to know what my chances are of getting some 17x9 - 3 (225/45) & 17x10.5-17 (235/45) on a 33 gtst
i know more then likely they wont fit but thought id ask anyway.
Thanks
