also 17x7 +~25 will look aids with any tyre size
Good AIDS or bad AIDS? :D I've got this good looking set thats going cheap ... 17x7 +35 - would love to see if someone has anything similar, went through around 50 pages last night didnt find anything close :P
ok, 25 mm hubcentric ichiba spacers should be on there way soon, Will be on a set of 18x8 +30 offset all around. Will post pics once installed.
Also someone was mentioning to me that with spacers the arms of the car will naturally toe in casueing camber? can anoyne shed light on this?
Or it was lowering the car will naturally casue camber. a little confussed on this
Edited by sydking
I'm going to be running 9.5+22 all round very soon, I'll put up pics when I get them
Cheers looking forward to the pics im planning on getting new rims in a few weeks that size and offset :P ill post up pics when i get them fitted etc... most likely need to roll the guards what tyre size you running do you know yet? was thinking 235/40/18 fronts and 245/40/18 rears
Edited by DarkRyda
can some one plz post a side on pic of 18 x 10 + 20s side on? and aslo 18 x 10 +12 side on? on a 33 GTR plz
And when i say side on i mean so i can see how flush or how far they poke outside of the gaurds.
Yeah 235/40 all round, it's a very common size so much cheaper than 245/40
Hey guys looking to get work meister sp3s 18 x 9.5 offset +16 on a 235/40/18 on s2 r33. Im going to take out the inners and roll the guards and run approx 2deg neg camber all round. Question is will the fit/ anyone got pic of s2 with similar spec wheels
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
