I run 18x9.5+12 w 235/40/18 allround, tyres tucked. not cambered and not flared... I get no scrub... it's all in the guardwork
I cant see how it would be truly working without sticking out a bit n at least 1-1.5 degrees of camber...
Also stretched tyres are something that i dont really count as admissable technique for something fitting.
id be keen to see pics of that Joey... No wait you do at the top of page 86 n you indicate a +22 offset, not +12 as here though.?
I can see that setup being +22 (and ill say it looks reasonable) but not +12...
Edited by jjman
Thats the thing with wheel fitment and this thread.
The problem is everyone has an opinion and what's really missing is the key aspects to fitment. How much guard work you prepared to do, how much camber do you want to run, what size tyre do you want to run and if you like stretch or not.
Until these things are sorted hard to recommend an offset or width.
18x9-1 215/40 Front -3 Camber could get away wtih a 225
18x10+18 225/40 Rear 0 Camber i do have a 25mm flare could get away with a 235
Going to dial in more camber on the rear probably -2.5 and massage the guards abit more as i'm going for some crazy fitment.
Mind you that the car is track orientated and i wouldn't recommend running what i plan on doing on the street as you'll be hassled and defected straight away haha
Just ordered a new set of boots for my 32 gtst.
17x9.5 + 18 front
17x10 + 18 rear.
Will let you know how i go ;)
Well i've only had a chance to test fit so far, but it's going to be abit of fun!
post-75263-0-46425200-1339733957_thumb.jpgpost-75263-0-50023100-1339733934_thumb.jpgpost-75263-0-49378600-1339733979_thumb.jpgpost-75263-0-15323700-1339733999_thumb.jpg
that was a +25, current rims are +12's and of course they stick out a little... never said they didn't.
tyres aren't really stretched, we are talking a 235/40/18 on a 9.5 - it's within the required specs of most tyres i run and only 1 size smaller than ADR's reccomend (245/40 legal minimum)
What suspension joeyjoejoe?
greddy type s 6kg rear 8kg front (wound up to max) superpro castor bushes front and superpro camber bushes front and rear. selby's swaybars front and rear. superpro pineaple bushes (set for grip).and gteck rack spacers.
18x9.5 +15 with a 235/40 18. guard lip rolleds up 100%, camber is set at - .2 with whiteline camber arms, about 3mm off guard, will put camber to -1 before the next track day. front is -2.5 camber, hits guard liner, no big deal
Wont that require a lot of guard work?? I am not a fan of the stretched look....so want tyres that sit flush basically...right up to the ends of the rims if you know what I mean...also what about rubbing on full lock??
can anyone tell me what sort of rims these are??
i'm sure i've seen them a million times before but never saw them on an r32 till now.. and would definitely consider these after seeing this!
look for photos of r32 GTST with R33 GTR rims (17x9 +30)
Will give you an idea.
Here is a photo of 18x9 +30 (username: timr32gts)
Looks like xd9's ....
indeed they are! thank you sir.
another inquiry. the following are pics of an r32 i was considering buying back in 2006. i have a question re the rims on it.
i know they are an american brand: HP design. model - HPR5
the ones on this particular car were 18", but i don't know what width that is on the rear. from my own research, every 18" example of them i've found was +38 offset and was available in 18x8 & 18x9 (+38 on both). so i'm picking the fronts are probably 18x8 but can anyone shed some light on what width those rears are? i've been a bit apprehensive about getting 9" rims for the rear of my r32 because i know a lot of the time there is guard/lip work involved, and i dont want any of that. but i was thinking 9" with a +38 offset may work even because it sits inwards just that little bit further than most other 9's? because i'm pretty sure this particular car had no guard work done. and if i can still get the rear down to a nice height without any rubbing that would be awesome.
this is pretty much the exact fit i'm going for, so just want some insight to whether the rears are 9" or 8". these are the most telling pictures i have of it.
chur!
25396297 full
25396196 full
25395936 full
thinking of getting work meisters sp1 3pc wheels.....want to run 18 x 8.5 +29 fronts...and 18 x 9.5 +24 rear....is that ok for the rear??? other option is +37
THANK YOU
go the +37, +24 will be pretty mexican. +37 will be flush with the guard and look great (will require rolling/cutting the arch guard on tho unless u want to run excessive camber or if the car is lowered).
+37 and some good 265's or 275's and you are in looks and traction heaven...
Edited by jjman
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
