Jeremy - to give you an idea of the rears - here are mine in 9.5+25. IMO its pretty fat stance without being over the top.
Keep in mind my car is high as a kite - dropping it would tuck them in abit more if your not into them hanging out...
You can just see the chrome lips either side of the car in the first pic :D
Any on know if these will fit my R34 GTR, the description confuses me ( happens easily ) I know GTR's have pumped guards, but i don't have a wide body kit....?
http://www.ebay.com.au/itm/230759854482?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_500wt_922
let me know what you recon!
Looks tough!
What size tyres/ how camber are you running? Much guard work?
What about size/offsets etc on the fronts?
Looks tough!
Tires are 245/30/20.
Camber I am unsure of, but the guards have been rolled and ever so slightly pumped.
Fronts are 8.5 +25 - the need a 10mm spacer IMO
ok so money pending i maybe able to get some xd9s
they'd most likely be 18 x 9 all round, can get +20 or +30 offsets, what would the best way to go for a 33 gtst
same offset all round or stagger? and will it only take a roll of the gaurd to fit 9's on the front,
i have stock height now but prob will get coils later on...
please dont say get 9's and 10's...
thanks
10" wide wheels on a R34 GTR fit easily. They don't state the offset, that's what you need to know. Too small for a 33 or 34 Gtr IMO, most run 19x10.5 +15 to + 24
Skyline model = R34 GTT
Wheel diameter = 19" meisters S1 3p
Wheel width = 9.5" all round
Wheel offset = +36 all round
Tyre size = front 225/35 KU31 stretch & rear 275/35 nankangs
Modifications to fit = existing coilovers very low....
Fronts - extended studs, 5mm spacer (slight rub on internal plastics, have to harden Susp)
Rear - nothing atm...... internal of wheel just touches coilover when going up a high driveway & high speed cornering scrapes lil rubber but I will be puting a 2/3mm spacer and Gonna roll rears so these issues won't occur.....
If your Questioning why?? I got an awesome deal on meisters
Edited by Tough R34
Im about to put 18x9.5+22 225/35 on the front and 18x10.5+30 245/35 rears on my r34 gtt. Should be a VERY aggressive fitment. Thoughts?
Post pics when you get it done.
You will have a bit of poke and need some guard work I think
thanks
ok so i want to order wheels now, prob going to go the +30 route for 18 x 9 xd9's
everything will be ok up front?
^^^^ you will need a roll up front , might get away in the rear but i'd roll rear to be sure as you will most like dump the car in the future , might also need to run camber up front , if you have rolled your front and put those wheels on, the front gaurds will eat the outside wall of the tyres your running, get 18x 9 + 25 all round , staggered fitment isnt a must mate. Xd9's ftw
Thinking about getting some works with
Front: 17x8 Inch +36 Offset
Rear: 17x9 +36 Offset
Would i have any issues fitting these to a r33 gtst with stock suspension?
Fronts will look weak but rears will be ok
<p>
<br />
10" wide wheels on a R34 GTR fit easily. They don't state the offset, that's what you need to know.  Too small for a 33 or 34 Gtr IMO, most run 19x10.5 +15 to + 24<br />
</p>
<p>so i need to know if they are +15 to +24? mmm im trying it decide what to do wheel wise, currently running heavy 18inch nismo copies for my semi slicks and 20" work SC1's on the street. be nice to get a set of 19x10.5 ROH Modenas.</p>
<p> </p>
<div id="myEventWatcherDiv" style="display:none;"> </div>
18x9 +25 is going to sit out of the guard 5mm more than +30...
Also, if he rolls the guards the lip of the guard won't eat into the outside tyre wall. That is part of the reason you roll them.
18x9 +30 is the same size as 34gtr wheels and they seem to fit quite nicely on 33gtst's and 34gtt's
Edited by Mitcho_7
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
