guys- who's running 18x10 +22 or near size wheels & how much camber are you running to tuck them?
currently has 235/40 and they stick out a good 15-20mm~
got defected for them sticking out so only solution is to tuck them in as i dont want to change wheels,
last alignment i had was -1.4
i'm thinking close to -1.8-2 as i will be lowering it bit 20mm more so the top of the tyre just tucks in.
I am assuming this is on a ST/T, not an R.
At that offset the entire rim will never be inside the guard. Adding more camber will just make the bottom poke out more.
Near flush on a GTST rear with a 10" wide is 30-35 offset and a 1.3"ish" in. Not sure what your regulations are to maintain a roadworthy car where you are at but it sounds like you'd have to either change your offset or possibly get flares to cover up. The others on here will have better insight on your local laws than I.
Another question guys. Looking at a set of wheels and I'm not too savvy.
They're 18" and 8" wide all round ET40. for my r33. Says 73.1 centre bore. Just wondering how they'll fit/sit. Cheers for the help :)
Get something with lower offset (e.g. +20-+30 for an 8"). Also depends how you want the wheels to sit.
Those ones will sit pretty much like the standard wheels.
Skyline model = r33 gtst
Wheel diameter = 18
Wheel width =9
Wheel offset =+20 on the rear that's all I'm looking at
Tyre size = 225 or 235
Modifications to fit = ?
Dose anyone have pics how it will sit. Car is lowered on coilovers
  • 1 month later...
Skyline model = R33 GTST
Wheel diameter = 17
Wheel width = 8/9
Wheel offset =+40
Tyre size = 225/255
Modifications to fit = None
Wheel: Inter Milano 17" Wheels
On the other hand
Wheel diameter = 18
Wheel width = 9/9
Wheel offset =+15
Tyre size = 225/40 245/45
Modifications to fit = Won't fit, hits side skirts, hits guards, hits everything. Need smaller profile.
Wheel: D1R's
Car isn't all that low either. I have 115mm clearance at the lowest point. I've gotta wrap the new wheels with 35 profile on the rear and can MAYBE get away wit 40's up front.
what would be the better option for an r32 gtst 2 door, 17x8.25+25 or 17x8.25+35? will be running 235/45 tyres all around, i know i can tuck both under stock guards but i want to be able to tuck the rears with between 0-1 degree negative camber so which would be the better option? guards are currently all stock but wouldnt mind rolling them, not to keen on doing much more, thanks!
Might as well post up my current setup
Skyline model = R32 GTST
Wheel diameter = 18
Wheel width = 9
Wheel offset =+27
Tyre size = 225
Modifications to fit = bit of camber on the rear from lowering the car
Wheel: Rota g-force
Does anyone have issues with front wheels unable to full lock steer or touching the front most point of the side skirts in their 33? I don't know why but just looking at my car from the side, the wheels look to sit further back of the centre of the wheel arch...
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
