guys- who's running 18x10 +22 or near size wheels & how much camber are you running to tuck them?
currently has 235/40 and they stick out a good 15-20mm~
got defected for them sticking out so only solution is to tuck them in as i dont want to change wheels,
last alignment i had was -1.4
i'm thinking close to -1.8-2 as i will be lowering it bit 20mm more so the top of the tyre just tucks in.
I am assuming this is on a ST/T, not an R.
At that offset the entire rim will never be inside the guard. Adding more camber will just make the bottom poke out more.
Near flush on a GTST rear with a 10" wide is 30-35 offset and a 1.3"ish" in. Not sure what your regulations are to maintain a roadworthy car where you are at but it sounds like you'd have to either change your offset or possibly get flares to cover up. The others on here will have better insight on your local laws than I.
Another question guys. Looking at a set of wheels and I'm not too savvy.
They're 18" and 8" wide all round ET40. for my r33. Says 73.1 centre bore. Just wondering how they'll fit/sit. Cheers for the help :)
Get something with lower offset (e.g. +20-+30 for an 8"). Also depends how you want the wheels to sit.
Those ones will sit pretty much like the standard wheels.
Skyline model = r33 gtst
Wheel diameter = 18
Wheel width =9
Wheel offset =+20 on the rear that's all I'm looking at
Tyre size = 225 or 235
Modifications to fit = ?
Dose anyone have pics how it will sit. Car is lowered on coilovers
  • 1 month later...
Skyline model = R33 GTST
Wheel diameter = 17
Wheel width = 8/9
Wheel offset =+40
Tyre size = 225/255
Modifications to fit = None
Wheel: Inter Milano 17" Wheels
On the other hand
Wheel diameter = 18
Wheel width = 9/9
Wheel offset =+15
Tyre size = 225/40 245/45
Modifications to fit = Won't fit, hits side skirts, hits guards, hits everything. Need smaller profile.
Wheel: D1R's
Car isn't all that low either. I have 115mm clearance at the lowest point. I've gotta wrap the new wheels with 35 profile on the rear and can MAYBE get away wit 40's up front.
what would be the better option for an r32 gtst 2 door, 17x8.25+25 or 17x8.25+35? will be running 235/45 tyres all around, i know i can tuck both under stock guards but i want to be able to tuck the rears with between 0-1 degree negative camber so which would be the better option? guards are currently all stock but wouldnt mind rolling them, not to keen on doing much more, thanks!
Might as well post up my current setup
Skyline model = R32 GTST
Wheel diameter = 18
Wheel width = 9
Wheel offset =+27
Tyre size = 225
Modifications to fit = bit of camber on the rear from lowering the car
Wheel: Rota g-force
Does anyone have issues with front wheels unable to full lock steer or touching the front most point of the side skirts in their 33? I don't know why but just looking at my car from the side, the wheels look to sit further back of the centre of the wheel arch...
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
