  • Replies 714
Posted Images
question...has anyone gone from jap coilovers say tiens hks to billies? what did you guys think of the swap? ive got tiens, love the firmness but hate all the bumps and knock noises that comes with it (bloody used coilovers and worn pillow tops)
gary, is it possible to increase the spring rates one stage harder with correct dampening and rebound rates in this group buy? have you gotten around to getting those circuit and drift setups completed yet for those gb's?
cheers.
Sorry guys I have been on holidays since the 20/12, I will get around to the hundred or so PM's over the next few days.
I don't have definite delivery date for the Bilstein shocks, but they have been produced by Bilstein Germany, so it is only shipping time. As soon as I have a confirmed date I will post it here.
All other items for R33GTST's are available.
:) cheers :(
Hi Sk, was considering replacing my rear springs from my tein HA coilovers with whiteline springs. Would these springs fit or do i need a special set for colivers?
The Whiteline coil springs in the Group Buy are designed for use with standard spring seats (top and bottom). So they won't fit a coil over shock with non standard top and bottom spring seats. I can organise Eibach (the best) coil springs, all I would need is the ID and free length of the current springs.
Wait a few days and PM them to me as I need to clear the inbox a little.
:) cheers :(
cheers.
Heaps of guys have done the upgrade from Teins, I get at least 5 enquiries a week. Every one so far has been ecstatic with the results, far better handling, more traction for acceleration and braking and a far superior ride. The guys who do circuit work have reported faster lap times.
So, the obvious question, why do you want to increase the spring rate? Springs are there to hold the car up and soak up the bumps, that's their job. Stabiliser bars control the roll. Anti dive geometry controls the dive under braking, anti squat geometry controls the squat under acceleration. The camber and caster adjuster increase the tyre contact pathc with the road/track. The shocks control the whole package.
Simply put, you don't need excessively high spring rates to have good handling.
:) cheers :(
Hey Gary,
It might be in the thread somewhere, but its not in the first post...Was wondering what the model numbers for the whiteline springs are?
I know you've chosen the shocks to suit them, and added the extra groove, but are the springs just a regular whiteline product?
cheers.
I'll save you another PM :)
After lots of hours spent replying and deleting, my PM inbox is no longer full.
The shipment of R33GTST Bilsteins is in the country, just needs customs clearance and local delivery. I would anticipate late this week or early next week. When I have a definite availablity date I will post it up.
But you can place an order from today, safe in the knowledge that it won't be more than 2 weeks till you have your delivery.
:) cheers :)
Hi sydneykid,
Damn your popular pm box always full when i try to PM! :P
I've had the bilsteins in my 33 for a few months now, using the stock factory springs. bit silly i guess but $$$!
How much stiffer a ride do you think the whiteline give compared to what im experiencing now with bilsteins using factory springs? Or is it just too hard to say seeing as what ive done right now has thrown the stock springs compression ratio out?
Also, are the whiteline springs the same size as stock? ie will direct swapping result in a lower ride height at all? Im thinking if not, but they are a bit stiffer, it might be wortwhile lowering the bilsteins another circlip groove all around. Thoughts?
Hi sydneykid,
Damn your popular pm box always full when i try to PM! :laugh:
What height is it now? There is a limit as to how low you can go with the standard springs.
:laugh: cheers :laugh:
PS; PM box has space
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
