Hi,
Just put some heat wrap on my dump pipe, the stuff that kinda looks like fiber glass. Anyway after the first drive or so there was some smoke coming from the tape that smells like Ski wax :huh:
I figure this will go away after a couple of drives but just wanted to check if anyone else has had this problem?
https://www.sau.com.au/forums/topic/85695-heat-wrap/
when you wrap it it's a good idea to wet it as you wrap. ie wit a section say 8 inches long, wrap it around and so on. then once it's all tight and secured let it dry. then paint it. will give a good result that way. and yes it will smoke a little and smell at first but it will go away.
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-1552836
  • 2 years later...
Sorry to bring up an old thread.
Im about to use heat wrap on GTR dump pipes. Beer Baron can you tell me the theory behind painting it and what type of paint you would use?
I plan to use metal cable ties. Cheers for the tip of wetting the fabric, i guess it will keep things in place until it gets secured properly.
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3654321
i brought up this very topic with my mechanic a few days ago. he has worked with nissan for seven years , and in the renault racing team in europe for about 3yrs.
in theyre racing cars he used to soak the heat wrap in water then install it, this would mould in shape. BUT it would smoke for ages after it.
eventually it should go away.
p.s i asked about the pipe cracking issue. he said its 'bullshit' on a renault 24hr le mon race he reckons that there was no problems.
and i would believe him....he has tested it.
Edited by r33cruiser
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3654682
Im curious to know why to put some paint on the heat wrap aswell, i have never heard of that being done.
Im not trying to say i know more than a mechanic or anything but i still have worries about the heat wrap cracking the pipe quicker than without the wrap. The way i see it, the wrap holds in the heat which doesnt allow the pipe to radiate the heat therefore putting more stress on the welds. (which i have seen done before) could have just as easily cracked if it was crappy welding anyway.
having a race car in a 24 hour race shouldnt do much damage because its only going for 24 hours and the car is sitting mostly at the one temperature. compare that to everyday driving where the car has to last years of heating up to big temps and cooling down to nothing on nearly a daily basis I would be worried heatwrap would reduce the life of the wrapped part.
Im about to put some heatwrap on my dump pipe. so ill find out myself
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3654835
paint the pipe. Cure it. wrap the pipe evenly (very important) and then paint over it.
The idea is to prevent moisture build up when cold and also does a little to protect the wrap.
Even application of the heat wrap is important so as to avoid hot/cold spots.
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655171
Yeh painting it helps seal it from moisture.
Regarding the cracking. The way i look at it its temperature differentail and rapid cooling that hurt the metal more then the ultimate temperature you run it at. When wrapped it ensures that the metal cannot cool quickly or be splashed with water on wet roads.
I wrapped ahd HPC coated my manifold and never had problems for several years. One time i had the manifold off and i was lazy and too cheap to re-wrap it, just running a heat shield. Since then i have had a few problems with cracking. Whether that is a coincidence as the manifold is obviously older and by nature more likely to crack as its older...or the more rapid cooling hurts the metallurgy of the steel and weld. Since the welds lack proper penetration they are the weakest point so most likely to fail at that point.
Anyway, thats my take on it. I woudl ceramic coat and wrap it. Ceramic coating by itself does next to f**k all from a temp standpoint...they work well in combination with one another. Just make sure you wrap it evenly. Leaving sections exmposed to air introduces the whole temperature differentials again which leads to internal stresses and fatigue cracking
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655247
lol sure mate. redlining every gear for 24hrs doesnt do any damage, and it sits at 1 temp.
WTF!!
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655378
WTF!!
i think he means its at a more consistant temperature then a road car which is probably true
cars bone cold, start it, drive 20mins, get hot, cools down, etc etc
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655444
Haha i dont think i explained myself right. I meant to say it sits at 1 temp being really farken hot for a long period of time so it gets hot and stays hot and doesnt have much chance to cool down and contract. compare to a street driven car where it heats up when driving, then goes cold when you stop. then heats up when u drive it again. therefore the metal would expand and contract more making it more prone to cracking. Ill stop now im sure im digging the hole even deeper.
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655445
I have known a few examples of heat wrap leading to fatigue and cracking, both instances were caused by uneven wrapping and no paint being applied. One example was my brother's car , he was a slack bastard and there were gaps that allowed condensation in. I re-wrapped his next set of extractors and he never had problem again.
I have heat wrapped lots of exhausts inc. rotary exaust pipes without any issues for many years. I've done this to so many cars including mates and never had any issues.
The absolute rubbish people go on about cracking is due to people not doing things properly. You notice non-wrapped stainless manifolds are far more prone to it. Hell even Tomei supply heat wrap with thier RB26 replacement stainless turbo manifolds, I wonder why? Maybe they want you to come back and buy more manifolds off them when they go and crack on you? Stupid!
Edited by rev210
https://www.sau.com.au/forums/topic/85695-heat-wrap/#findComment-3655955
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
