i found the best way to get ppl to notice me when i am coming down the street is too add a restrictor which will give off AWESOME cooler noises....best to use a potato and push it into your exhaust. Try not to let any of the exhaust fumes escape cos you are trying to aim for the pressure build up. Trust me...it worked for me!
  • Replies 52
instead of all that noise u want.. bcos its very possible it would attract the cops... why not put big shiny "GTR" stickers all over ur car.. That way ppl will know its a gtr just from the shiny stickers
I have a brotec se8 fitted on my sr20 in the cefiro.
Before having it people just thought it was a camry.. now I have people asking me if it's got a GTR engine or if it's a JGTC car!!
Good choice CC - the SE8 version of the Brotech includes the hertz regulator control module that can be used to adjust your cam timing in car while you drive. With the HRCM at its peak load, HP can be realistically increased by 25% instantly - even with stock cams. Works especially well on rotary powered vehicles.
i wont give you shit like everyone else "seems" to be
if you want induction noise your going to HAVE to put pods on.
the good news is that in most states one intake mod is allowed, usually either front mount/airpods, but considering GTR's already have a front mount you should be able to change pods without a defect risk.
I have taken my car through vehicle inspections in SA twice with pods on.
if your really worried you might be risking a defect call the RTA/email them in your state and ask "can i put airpods on my car, lots of other people have them but im not sure if they are illegal?"
Please don't get an emulator. You have a GTR man. A REAL twin turbo monster. People who don't have turbos pretend they have stuff.. you don't need to pretend anything.
I heard that sound clip of someone that said they had some brotech system, sound disgusting, maybe just recording quality....
And while we are at it, please don't put a bonnet scoop on it either! Or HUB CAPS!!!!!
hmm i dano,
brotech's work alot better with bonnet scoops.. my mate has one on his GTR, he only has a small scoop, but is upgrading to a much bigger one soon. He is also upgrading to the newer brotech, you can flick between 2.6ltr and 3.ltr on the roll! B) forget the name of the new one tho
hmm i dano,
I heard with the new one you can also swap between your big single turbo for 3ltr mode or your high flowed twins on 2.6ltr mode, on the roll of course.
Did I hear correctly????????
lol i made a dik of ma self
i still new to skylines as bought my first car onli a month ago 32 gtr
oh dear!
LOL... you crack me up LOL... :lol: :lol: lol ouch my side
you should have said you were joking...
you should edit your post hehe
found this - www.takakaira.com/accessories/nightpager/nightpager.html
Ali-turko, dont mean to offend, but people like you are the reason people think skyline drivers are wankers.
what's real funny about this whole BOV/no BOV argument that repeats itself here is that the no BOV crew think it's cool to have the "pigeon" sound, which , correct me if I'm wrong, is just as attention grabbing as some of the bovs on the market, so before pointing the finger saying people that run and like the sound of BOV's calling them ricers etc, take a look at yourselves! Dont get me wrong, I hate those stupid "ultrasonic happy joy bus brake 3ssqvrt" Bov's as much as the next guy, but I run a greddy type s BOV that is not designed as such to whistle, but is just a by product of it's construction, and something which I do happen to like the sound of. It's not intrusive, and doesn't make people I'm passing think something is wrong with my car, it's just enough to know it's there. My car also came with a pod filter which means if I do the plumb back option, it ends up sounding like afore mentioned bus brake BOV, which I hate the sound of so dearly. I would actually like to quiet mine down a bit because I am very conscious of the volume of the sucking sound you get from the pod filter, but I'm not really sure if there is any option other then to revert back to a standard airbox.
So, bnr, after all that, the easest was to get a bit more noise that i've seen (which i think is a bit silly and cheap looking, but none the less) is to drill a whole bunch of holes in your airbox on the dirty side of the air filter. you could also remove the resonating chamber from the airbox (the one that usually goes in to the inner guard - also kind of a cold air intake - it's designed to reduce sound emissions).
Honestly, what's wrong with having a turbo and wanting it to sound more like a turbo?
Edited by jezzerrr
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
