Hey, i was just wondering, here in sunny Brisbane, do u need (by law) to have a license plate on the front of your car? A few people have told me now, but i was just thinking, a few of u guys have really good front bumpers, and well do we need em?>
https://www.sau.com.au/forums/topic/87190-license/
well yes i am, some other guys i met with r33, had no front plates as it didnt have anywhere to fit on there aftermarket front. they said that they werent required by law to have them on the front, but the rear is a must....
i know it sounds stupid, but is it true or not..
https://www.sau.com.au/forums/topic/87190-license/#findComment-1574775
I have heard this also, i do not know how much truth there is to it, but one of my reloes had a mx5 with no front plates, and i was like wtf, and they insisted they didnt come out with them because there was no where to put them, i was just like, yes ok...
Im sure you can get away with it, but you can also get fined on it. Ring up ur local tmu a few times, and i betya u get a few different answers regarding to it :P
just put it on, what harm is it doing?
https://www.sau.com.au/forums/topic/87190-license/#findComment-1574806
You rnumber plate is to be fitted to the centre of your front bar.... Fitting to the side is as illegal as not having one at all...
It must be perfectlly visable from a 60 degree angle at 20 metres...
I did my research the other day...
https://www.sau.com.au/forums/topic/87190-license/#findComment-1579313
Last time i checked the front numberplate could be mounted on the side but must still conform with the angle and distance rule thingo.
When did you check?
I never had a problem with it being on the side
Edited by «Cyph3r»
https://www.sau.com.au/forums/topic/87190-license/#findComment-1591495
As long as it is viewable as above standards you will not be booked. But you can never tell if the officer that pulled u up is in a good mood or not...
I have never had a problem with mine being side mounted either. But a friend of mine had her plate zip tied to her front mesh, and when she drove it folded up so you couldnt see it, and she got pulled over, and told to fix it or cop a defect. I think it depends on the officer you get too, but if they are in a bad mood they will do you for anything.
https://www.sau.com.au/forums/topic/87190-license/#findComment-1596523
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
