  • Replies 72
If you are able to retain the factory airbox then consider it's going to require effort and money to make any pod setup just as good. You can also modify the factory airbox with an extra or better air feed to improve it at low cost too.
An airpod is really for when you have gotten stuck with turbo plumbing on big turbos that are larger or some other situation. It's just a part of a bigger bloody hassle that comes with bigger power setups.
Try a dyno with the bonnet 'down' and see how much power a pod loses over the factory airbox. You need a very good cold air induction box to get back only what you lose, hardly worth the effort. Every comparison of 'Wonder Pods' I've seen showing power increases was done with the bonnet 'up', rather pointless.
I have bought recently an R32 gtst with a pod and only a stainless partition in place, The partition does almost nothing (it gets very hot as does the pod inside). Suffice to say I am fixing the issue but, I'd rather not have to.
Some drag cars don't bother with any filters or airboxes at all because it isn't the power they are that concerned with losing so much as the abillity to get what power they have (more than they can use sometimes) through the drivetain (without breaking) and to the ground (controling the traction and transfer). They also strip the engine quite often so little extra bits of dust aren't worried about so much.
You gotta replace the turbo/AFM pipe if you wanna keep the airbox.
it has a very bad habit of being sucked closed, even more-so on GTRs :)
yeah found that out...the car will nearly stall...not good for the turbo either.
I will replace with a new AFM pipe but didn't have time so just wacked on my boxed CAI + Unifilter pod for the moment...1.3 bar is running nice with it :D
On the dyno it was happening at about 235rwkw mark. As for power loss...well if there is NO air...no pwr.
As for the topics of ARC boxes...for a GTST you can only have 1 intake mod in Vic...so choose between the the stock airbox and IC...we all know what needs upgrading first. 4 a GTR.. no dramas.
SO in summary...intake stock setup is good for about 230rwkw....need to replace both the filter and the AFM pipe - or wotever its called, the one to the turbo. Or for my setup it was good to 0.95 bar or roughly 235rwkw - on my setup.
Some ppl pms me about how I know...it was on the dyno..I saw it!
I have seen dyno results with the factory hose replaced with an aftermarket pipe and it actually made more power, apparently the ripples in the factory rubber hose can cause the air to be disturbed fairly dramatically.
So this means there IS a restriction with a stock box even if u replace the intake pipe ur only masking the issue. How much, dunno. But its obviously a restriction if it doesnt occur with a pod. However with the pod ur missing out on other things like colder air and pressure drop so prob. evens out in general.
So you can just knock another hole in the lid of the stock box to try and fix the restriction...But I actually took my lid off on the dyno and saw the pipe still suck in a bit.
So for me its:
1. New Intake pipe.
2. New Lid and snorkel to look stock.
3. No defect issues
So for me its:
1. New Intake pipe.
3. No defect issues
Its quite possible the intake pipe its self is contributing to the restriction, its quite lumpy in there and we all know air likes a smooth flat polished surface. Which is why exhaust ports are polished. Improve flow due to reduced turbulence.
Either way I think the best option is to replace the intake pipe. The turbo is doing the work sucking the air so there's no direct pumping losses as an N/A would experience with a slight restriction in the inlet tract.
So yes Mask the problem as you call it. >_< Its not necessarily loosing power anyway. Just keeping those defects away.
As said above. If the car were N/A its a complete different story.
N/A = ditch the afm, remove 'any' possible restriction there is as it all contributes to pumping losses.
Dont disagree. But during the test I replaced the stock box with a pod and issue does not occur at all. So therefore my point was the pipe is not the main cause of restriction as it remains constant in the test, however crap it might be .
If ur gonna go to the trouble of replacing the intake...I might as well do it properly and remove all the restriction buy venting the box lid better.
As for NAs...I have made about 3 setups for my NA fto. The stock box with new intake pipe got me about 4rwkw of stock...cos the stock one was so bad, the pod gave nothing...infact my testing showed slight worse results with the pod.
I think the primary problem is the size of the inlet on the stock GTSt airbox, not the actual filter area else GTR's would have trouble with more power.
The ribbed pipe is secondary but can be a major issue when sucking closed at higher power and on hot days so clearly that has to go.
The solution? For me it is a black painted FMIC, opened airbox with Apexi filter (oiled are illegal, see attached docupic from Pauls website so K&N are out) and a replacement hard pipe also black. Leave the heat for the ricers with pods and shiny "look at me, I'm an attention whore" FMIC.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
