Yes that would be the ideal way, it would be a hell of a lot easier on mybehalf too!
From last experience ie dinner cruise, we had lots of interested people but only one person rocked up. The only reason why iam doing the deposits is to make sure we dont waste Shauns time, as he could of booked other things on the day.
I thought this would be a good idea to get genuine interested people and reward them.
THose are my thoughts.
  • Replies 294
Agreed :)
My car is off the road thanks to some 4WD owner who cant reverse, crashing into it with the rear bulbar. Ripped my brand new cooler and bumper (put on 2 days earlier) off and pushed radiator and fan back into engine. If my car is back on the road by this time i will still attend otherwise i will have to give it a miss!. f**king P plate 4wd drivers!!
Someone deposited
10/10/2005 DEPOSIT 9999 5115
Who is this? You didnt put any name!
Yep thats mine, bank lady didnt know how to put my name in the transaction and the other teller told her to enter 9999 then she would be able to put a name next to the transaction, i guess it didnt work, but thats my payment from monday.
Updated first post.
Also, this is the order so far. Just let me know on the day if you dont like where you are and maybe I can change it.
SAU PEEPS COMING
NAME-----------------PAIDYET?
1. lang Yes
2. MS-75 Yes
3. Jagged Edge Yes
4. Chris32 Yes
5. GFXman Yes
6. syx Yes IN FULL
7. gtrGhosTDOGG11 Yes
8. sky30 SOON IN POST
9. ?
Edited by gtrGhosTDoGG11
I noticed that 10 people haven't deposited yet so I just did so then. Should show up tomorrow hopefully.
Even though my clutch slips, its only sometimes in 4th so if I drive it there easy and dont heat the clutch up, and get the dyno done in 3rd, hopefully it'll be OK. Haven't had it run with the cooler on yet so it'll be good to see how it goes even if the clutch does slip during the run.
Its already installed.
I'm running a dedicated feed from the battery via relay.
Under load its only seeing 11.something volts.
Not the 13.8 as it should. :)
Then later on I will ditch it and throw an 044 in there, I'm currently running a 910 that won't cut it for over 250rwkw. :)
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
