  • Replies 169
Posted Images
I'm sure she's a member's sister or girlfriend or something so try not to be rude guys.
I second that. Wouldnt like it if it was my girlfriend. Nicholls, shame on you *slap* :P
The next "show 'n shine" is next year :lol:, but last night the committee planned out cruises, events, etc. for the next year and boy is it going to be busy. Make sure all your cars are in drivable condition :), otherwise you'll miss out. At least one event per month!
i better get my ass into gear and get a 33! or maybe THEY should get their ass into gear and find me 1...
Dezz, are you looking at buying an R33?? Why haven't you mentioned this before!!?!! :D
HAHAHA :lol:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
