phhhpht... yous got it all wrong... wen get out of the car go and rip the fuel relay out so the fuel pump dont start... my mate did that with his vl thru hi school and never had a problem :)
  • Replies 51
Bottom line is if they really want to steal it They will
had a mate who owned a vk Brock took it to calder took rotor button out took relay out for ignition the only thing we come up with is that they trailered it out whilst we were in side
or rolled it out. had a fellow in parramatta that lost a S14 the same way. new car (2004 when I did it.) had quiktrack on it. no problems now.
in regard to theft of vehicles, if I wanted a lot of vehicles quickly which would I do: ( I have a light truck licence btw)
find a group of mates and go pinch a few cars all at once OR
pinch a flatbed. have a think about that one..
truck is definetly the best way, if a theif really wants something quick and easily they wont stuff around with ur alarm they will just put it on a truck and leave quicksmart :P
which means that if you are really worried about your cars security either dont leave it anywhere or get a tracker as chris has said many times
A little trick a friend told me as he is a towie when you park you car, turn the wheel to full lock into the kerb then lock it, if thay try to drag your car up onto the tray the car will want to turn, which makes it that little bit harder to take.
Honestly IMO, the best way to install an alarm is to do it yourself, then everything is customised and not wired the same as every single car on the street.
I've got my entire alarm wired totally different to most or all cars, the box is actually on the left hand side of the car and all the wires are routed together with the stock wiring so when a crook pulls out the wiring it looks like there's no alarm attached...
Using a BW10000, I managed to get 4 pt immobiliser outta it, hooked up a pile of relays in parallel to each other...
got one for fuel, starter, power, ignition...
  • 7 years later...
Believe CHRIS ROGERS when he tells you anything about alarms ect. My r33 GTS-t wouldn't unlock the other morning and the immobiliser wouldn't turn off. I gave Chris a buZz and he came over. Turned out I had 2 alarms in my car and one died hence the issue. No bulkshit he had my car running in almost 45sec. He is the only one who put alarms in ANYTHING I drive. Because when he does it he does it with his own experience at hand and fits them so there as hard as possible for him so damn near impossible for anyone else. Chris's a alarm /Auto Elec GURU.
Thanks heaps for your help mate.
Maybe but the fellow that posted and bumped the thread was privy to me hot wiring and bypassing two alarms in under 45 seconds.
He has a right to be happy that I did it before a thief did.
Anyone recommend a good place on the Gold Coast where I can buy & get them to install the alarm PROPERLY..
I would try it myself as stated in this thread, but when it comes to electrics.. I'm fried :)
Not really looking for anything too exy, the car will be locked in fence and garage but still..
Edited by Zrobe
run it up to me and I will do it.
phone number in sig.
No worries, I'm on phone so couldn't see your sig.
Didn't realise you we're in Brisbane.
When I do get my alarm (probably not for a while, car is currently not running) I will take it straight to you.
Are you also able to remove my current alarm? Was on with the car when purchased and stuffs around every now and then.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
