Well after a few interesting weeks of having her gtr of the road and in pieces it is finally all back together and going again with a steady idle just under 1k, all that's left to do now is a few highway runs tomorrow to set the boost controller up...
Old Engine bay shot.
New Shot with pretty bits fitted...
got new tyres for the 31 today
$107/each fitted (in QLD) for 235/45/r17 Achilles Sports (supposed to be very good for the price)
anyone know of anybody in tas who can get deals like that?
(this was from Japanese parts and performance on the gold coast)
Just in the process of sliping the motor back into the R.
then make up a few oil cooler line's,fuel line's, fire thold girl up.
then strip the inside of her out, then off the Chris Tanner @ Performance Fabrication
for a full cage,
Then into the spray booth at Robayne/Optimum coating's for a fresh lick of paint.
quick tune at Pro Auto and back on the road hopfully...
easy way to spend $7-10G's in a few month's!!!
my new pcv valve arrived :D
popped that in and it seems that everything is back to normal (was doing a couple of tiny weird things before)
$23 from launceston nissan, $11 from Amayama :)
Been a while since i've been on here , 34 is 'garaged' at another location atm because lil scum tried to break into it again and stuffed the door locks (which did their job thankfully) . Will fix it up soon enough and sell it on , which i'll be doing with all my cars now , gunna get out of the imports for a while i reckon
hey guys dose anyone know someone that could do a bit of sanding/priming for me? (rear quarter needs the line sanded back into it near the tail lights)
would preferably like it done before Saturday
Cheers
A decent amount of stuff happened with my car over the last few weeks.
Had a knocking noise the other day as I pulled into the driveway, which turned into a horrible rattle/scraping noise the next time I started it. Had my mechanic over and he thought it could be the timing idler/tensioner coming loose, but it turns out it was the harmonic balancer wobbling around and it was rubbing against the engine.
It had eaten out the keystone on the crankshaft and created a lip in front of the timing gear, and because it had arsed up the crank a bit we were worried it may have screwed up the timing gear or it's key stone/area on the crank as well. Ended up pulling it all down and replacing the water pump, crankshaft seal, timing belt (with a full new kit) and a new crank timing gear because we ended up drilling the other one off :P a bit early for the timing service, but meh.
In slightly more awesome news, I got my new QFM AR1M brake pads the other day, just need to get the rotors machined and get them in now :D Also, my car has a few goodies stolen off Veeto's poor car now, the 3.5" exhaust system and the rear strut brace. She's running a lot tighter and louder.
finally after 3 months or so of ben and i tinkering ive got my streeter running sweet. best its run since i got it just in time to go to a new home. haha
ive had a battle as the cause of my problems was multiple sensors. one was just masking the next.
ive always had a thing against selling cars just once you get them sorted but i can see how the frustration can cause people to just want to see the back of a car.
i can now garentee it will go smoothly for the next owner.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
