Yeah Jangles got it.
Needed something to tow the skyline with because I can't always be counting on my old man to come down when I want to take her out.
I'm really enjoying it! Very nice to drive.
hey guys bit random but here is a quick video i took today was just wondering dose this sound like stock cams? ( or is it just the 26 internals making it sound like this, sorry for crappy quality was taken with my phone )
http://www.youtube.com/watch?v=TMPIFClwW18
cheers
There will be no Nav gearing up. It's good to go!
Maybe some new speakers... and a FMIC.... Slightly bigger turbo wouldn't hurt.... maybe some spotties too... hmmm, wouldn't mind a tool box in the tray... side steps would be nice too... and a sports bar in the tray... Winch would be handy... 2 inch body lift would make off roading more pleasurable. Need a compressor too... EGT gauge would be a wise investment also... might get a piggyback ecu for it too. I'll need a bigger zorst then too. Sorkel will help getting to work on those rainy days...
hmmmmm
cheers
so hard to tell over video, whip cam covers off and have a look for stamps on cams?
yeah, lots of things could be making it lumpy. You need some big f**k off cams to make an RB lumpy though.
There are heaps of threads on how to make a 27 from 25/26 parts, you use a RB26 crank, rods and pistons with an overbore of .88mm or 1mm i cant remember. or you can buy the 2.7 stroker kit
mine has been done using forged oversized 26 pistons rods ect had the head bored, ect also has a thicker head gasket ( i'm not sure on thickness)
The motor build cost around 10k so it was done properly
edit: one of the few threads on here about them http://www.skylinesa...27-info-needed/
http://www.skylinesaustralia.com/forums/topic/321488-rb26-crank-in-a-rb25/
Edited by Autumn33
fitted up my 1000cc injectors and modded fuel rail tonight. started and moved it to the workshop ready for a few hard nights to get it ship shape for tuning.
hoping to get to the final round of the drift series.
so i been playing around trying to get my engine bay lookn better thought id add some pics of wen i brought it and wat it looks like now engineold1.jpg
i really dont know who he got so much dirt mud and wat not in the engine bay
also waiting for the vipec 2 come from NZ so next week should be a good1 :D
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
