installing my new fuel pump from tuff car parts today aeromotive stealth 340 :D
so turns out the "GTR" fuel pump is missing? and in it place was a stock old std pump with no filter sock -.-! so glad i got a new one that could have killed the engine ? ( no filter = sucking shit from tank= fuel block= death?)
the block who had it befor me got a garage in L'ton to install a new gtr pump because they said his old one was stuffed turns out they ripped him right off :domokun:
Hi guys,<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">Had this R32 for a couple of weeks now and she wasnt running the best. And as I plan on goin to Melb for chrissy holidays I decided to take her in to get tuned and dyno'd.<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">So with the following mods (next to nothing... lol) this is what she ran<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">
  • 3" Turbo back JJR exhaust
  • R33 turbo
  • Turbosmart Manual boost controller (Bleed type)
  • Turbosmart Boost gauge
  • A'pexi SAFC II
  • HKS turbo timer
  • HKS style pod filter
  • Stock fuel pump
  • Stock Injectors
  • Stock coils
  • Stock cam
<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">This will be classed as the "Before" dyno, as i plan on goin back to JEM after chrissy lookin for 250+ rwkw... :)<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); "><br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">DSCF0769-1-1.jpg<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">DSCF0764-1.jpg<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">DSCF0815.jpg<br style="color: rgb(28, 40, 55); font-size: 13px; line-height: 19px; background-color: rgb(250, 251, 252); ">DSCF0914.jpg
Hi guys,
So with the following mods (next to nothing... lol) this is what she ran...
  • R33 turbo
  • A'pexi SAFC II
  • HKS turbo timer
  • Stock fuel pump
  • Stock Injectors
  • Stock coils
  • Stock cam
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
