just need to get some nice new cooler clamps
tamar marine or other equivalent hobart chandlery
they have heaps of sizes, all stainless for about $10-15/clamp and they are the good bolt ones, not worm gear ones
neither, was in there to get some self amalgamating tape (rubber tape) to tape up my coil packs
i think i'll have to get some for mine now
i honestly wouldnt waste your money on them if youve already got hose clamps,
few high psi/hp cars i know of run the 'worm drive' type.
unless youre removing your intercooler piping often, they should be fine
Thats the the gayest thing ive seen in a long time. You have issues.
Your selector forks and syncros will love that.
Seeing as it's a 'fashion' item, how will it affect selector forks and synchros? Unless he is hanging off the top levering the gear once the gear is selected?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
