Received my pipes today,
slight mix up when posting so I got a set without a flange but the guy was a champ when i rang him & refunded me the price of itthumbsup.gif
nice pipes mate :thumbsup: cut the inside off about 20 mill get some offset going :D
Howdy,
Couple of questions. I've got an Nm35 Stagea
Where's the best place to get an immobilizer/alarm installed? Do most of you buy a kit off ebay and then get a place like Hobart Audio to install it? I recently imported the car and it's come with an alarm (and maybe an immobiliser) but my insurer quoted that I needed an 'Australian Standard immobiliser,' which has me worried if it got knocked off.
Also, where's the cheapest place to get a dump and catback installed? I rang up Moonah Mufflers and Carline and the latter seems the cheaper for an install.
Cheers
best bet is to get onto some1 on here thats down thay way and is a wizz on the welder / tig and get them to do it / make one, the exaust shops will cost you 10x wat there worth :) i dont know any1 down hobart way sorry
I'm sourcing the exhaust and dump in SA and VIC from those that have already custom built them for the m35. Just need someone to install them.
I'll pop into Auto Addiction and see what they can do for me.Cheers
I have no idea how difficult this would be in an m35 but I change the r33's exhaust over about once a month and am a self maintenance newb. I have a track exhaust which gets shoved on and then I have my stock one for normal driving, keeps the neighbours/police/wife happy ;)
Prop her up on some axle stands and have a good look how difficult it is, if it doesn't have a robotic goat under there bleating at you about safe sex you're probably going to enjoy doing it yourself. I'd be keen to help out (goat aside) if you want a hand, and I'm sure I can volunteer another few people off here too :)
I've been told that changing the dump on a m35 is not a fun task at all
I hereby retract my offer of help. Your goat is outside my area of expertise.
Go somewhere like here http://www.yellowpages.com.au/tas/kingston/kingborough-exhausts-12099199-listing.html
soo finaly got all my hids in ! LB is 10000K 35w kit and HB is 6000K 100W kit :) ill have to take a pic at night befor the std HB didnt make any diff oer the LB hids but now all i can say is it rapes signs and cooks ppls eyes thought id add a pic so you can see the diff the left side is with both hid kits if on :) if your a night driveing bandit like me i would get these 100w hids :) best thing iv ever done no more roo hitting because i didnt see them on the road
cut it from where the flange bend goes to the smaller pipe and weld the it back on? or you want it so you can swap at times?
Yeah i was going to do that but thought might be safe to have it so if i need to change them over i can thumbsup.gif
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
