R33 GTST
Auto
ET: 14.003 (on 5cyl)
MPH: 9x.xx??? (lost time slip)
Fuel: BP Ultimate
Tyres: shitty 205's
Boost: 16+psi (bleed valve shit itself)
Poweer: 190rwkw
bleed valve shit itself, i melted a piston at the start line when i started blowing smoke while doing a burnout before the race... but i didnt notice till 3/4 track which is when i started easing off.
new timeslip in a few weeks when my car is fixed and run in :P
Had mine out today at Heathcote, after a few runs managed to run a 12.2, details are:
ET:12.254
MPH:114.53
60':1.721
Tyres: Yokohama AVS ES100 225/16-inch
Nitrous: No
Fuel: Mobil Synergy 8000
Nissan: R32 GTR
Power: 248rwkw at 1bar
Will scan time sheet if necessary.
Hi,
R33 gts-t
3 Inch exhaust turbo back, pod filter and boost controller set to 12 pound.
Est power - 175 rwkw
60 ft- 2.098
1/8 ET- 8.845
MPH- 81.818
1/4 ET- 13.624
MPH- 102.975
Tyres- Bridgestones unsure of exact type. 225/50/16
Fuel- optimax (no bp ultimate available here :D )
No nitrous.
Video
Edited by bilbo117
I went quicker, gutted some more un needed things out of the car and new slicks.
R33 GTS V8 SC
ET: 11.56
MPH: 118
60': 1.69
FUEL: 50% Toluene 50% BP Ultimate
Tyres: 26 by 9 Hoosier Slicks
Boost: 10psi
Power: 380rwhp
R33 GTS V8 SC
ET: 11.22
MPH: 123
60': 1.67
Boost: 10psi
Power: 380rwhp
Changed to 1 7/8'' Primaries and made less power on the dyno... but i reckon its got more left in it..
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
