thanks for that, got bc coilovers going in this week. not sure what sort of camber ill end up with.
the wheel also comes in a 35 offset but thinking that would sit in to close to the strut and i don't really want to run spacers.
I did a few things to it over the xmas break
Tein Coilovers
Whiteline Swaybars
Cusco castor rods
Adjustable front upper arms
S14 subframe (no hicas) to convert to eyelet rear struts
Nolathane subframe bushes
Nolathane arm bushes in all rear arms
Adjustable rear upper arms
To Do shortly
R34 GTT 4pot front brakes
R33 GTST twin pot rear brakes
R33 GTST master cylinder
will be a struggle to fit i think. not only with gaurds but also shocker. does ur have auto or manual rear cradle might help as well. but a 18x9+30 just fits autos, **x9+28 fits with gaurd roll. so would be a tough fit i reckon if its got auto cradle in rear. but manual might hit shocker.
Tein Coilovers
Whiteline Swaybars
Cusco castor rods
To Do shortly
I have an R33GTR master cylinder BM57 -
  • 3 weeks later...
rota grids are affordable and are becoming a popular choice nowadays.
Heck yeah. as long as above isn't sarcasm.
Affordable means they can live on a daily.
How much poke if any are people gettiing on 19x9.5 +15s on manual C34s.
I want as little as possible, as mentioned its a daily.
Also how much scrubbing, and guard work is needed.
By my dodgey maths, it seems like as long as i dont go too low should be sweet.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
