If anyones wondering what 18" white Advanti Samurai's look like here you go. They are 18x9 +35 and 235/40R18 tyres. Minor stretch. I dont really like stretch but it was necessary as you will see when you scroll down. The bottom of the coil over adjuster nuts were rubbing on the rear tyres. Fortunately I just needed to raise the coilovers about 10mm. Its still pretty low though. If they had +30 offset I wouldve got that but anymore poke is just ricey IMO. Running 18x10 with 20 offset is not for me! haha. For the record this rim/offset is fine with TEIN coilovers set to a reasonable height.
For you guys still confused (and fair enough), this site helped me heaps, and kinda renders this thread useless, if it werent for the sweet stagea pics lol.
http://www.willtheyfit.com/index.php?width=215&aspect=45&diameter=17&wheelwidth=7&offset=45&width2=235&aspect2=40&diameter2=18&wheelwidth2=9&offset2=35#content
Just find out your current width and offset (should be on the rim, inside), check the clearance on the inside (suspension) and outside (guards) of your current wheel, and enter the specs of your new wheel.
You can see if I went with 255's it wouldnt have fitted.
  • 1 month later...
Righto, I've been looking and reading and looking and calculating some more and I've settled on 18x9.5 +15 with 265/35s all round on an S2 C34 RS4S.
It's running Bilsteins and it's got a fair bit of low installed but by my calcs they'll fit properly, without having to resort to crap camber to make them clear the struts.
Can anyone spot anything I might be missing?
You are legendary. Going by those pics they'll fit, although the clearance between the inner tyre and strut will be a bee's dick. Worst case I have some 5mm spacers to give a tad more clearance. Not ideal, but the car is just a cruiser so no biggie.
Cowboy1600, here's some more detailed pics, also a S2 C34 RS4S with 18x9.5 +15 but with 235/40's. Center of rim to the guard is about 340~345mm.
What happens when you throw it into a corner? You can get the same fitment and the same rubber on the road with 18 x 8in and 235 tyres:
It's not the fitment I'm concerned about, more the rubber. It's at 230rwkw now and the 235s on it now struggle. Once I decide on a new intercooler and get it back to Trent for a tune it should be north of 300 and 235s will not stand a chance.
I've converted to RWD so need 265s to tame the rear.
Sure - my comments were more directed at Jase with his big wheels and small tyres.
You just need to get your wheels away from the suspension and then take to the guards with a big hammer!
I know my set up is far from ideal, i will admit that. When i bought the stagea it had 18x8 with 235/40 tyres and 18x9 265/35 tyres with 20mm spacers front and rear. I dislike spacers and i was having issues with the 4wd because of the mismatched tyres.
The cst's popped up at a price i couldn't refuse and made them fit.
It handles just fine, i cant notice the difference the two set of rims it had.
OK, ended up with 18x8.5 +15 fronts with 235 40s and 18x9.5 +32 on the rear running 265 35s.
Fit is perfect. I had them roll the guards while I was there for a bit of extra room. It is rubbing somewhere but I I'm not sure where yet.
It's looks perfect!
It's looks perfect!
What are they?
Black always looks great against the yellow.
  • 1 month later...
Will a set of 18x9 +35 fit an s2 stagea rs four s?
Nope.
I've run into a problem with mine (18x9.5 +32)
They hit the strut on the inner lip going over bumps. I'mm going to run 10mm slip on hub centric spacers with longer wheel studs to get around the issue.
For 9.5s you want minimum of +22 i've decided, based on my experience. So 9s give you about 6mm extra clearance,, so you'd want max of ~+28 offset.
Nope.
Thanks! Now am looking at a set of Varrstoens, same 9.5 width, and come in 12 and 22 offsets. Any ideas which would be best? thinking 12 on front and 22 on rear?
9.5+12 will stick out a mile on the front, where a 9.5+22 will fit under with a 245 wide tyre with some minor guard rolling.
A 9.5+12 would probably be just about spot on for the rear; might still want the lips rolled lightly. Even the +22 looks bloody good, and having all four the same offset means you can rotate wheels easily.
  • Like 1
I've got 18x8.5 +19 on the front with 245s and they fit beautifully. We test fitted 9.5 +15s on the rear and they stuck out too far. +22s are spot on for the rear IMO (On a C34 rs4s). Will need guards rolled if the car has a decent amount of low installed though.
definetely not.
i got r33 gtr wheels (I know its 17x9 +30 but extra inch in the wheel would make mine much worse) on mine but the rears scrapped massively, got 15mm bolt on spacers but still scraps over bumps. I would need atleast another 5mm to clear struts over bumps. mine is lowered so if its higher or has adjustable camber arms could probably get them further away from the struts.
as for the fronts i have plenty of room no issues with the +30 but i would again go further down towards a +20-25 atleast.
Okay. just found out that my shop can get rotiforms in, and for wicked employee deals, so I am going to get a custom set of these made up. Going to stick with 8.5 wide to make choosing an offset a little more forgiving. I seen earlier in the thread someone said s2 rs4s should be good with +6 all around. Thoughts? Not opposed to guard rolling at all, would just like to be able to do without spacers.
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
