well something has to be done cos obviously it is a huge restriction on air for a front mount with all that shit there....
c'mon boys bite the bullet, you want air don't you get your dremel and cut it out, i went thru the same issues with my s1 dayz, you'll soon get use to it and theres plenty of trimming options out there to finish it off to look std. if you didn't want to cut your backing plate out you should have looked at s/mount options :)
  • Replies 254
Posted Images
My suggestion for cutting the front bar would to be find a plastic specialist that does plastic welding/ repairs and get them to cut it out and patch up the holes top and bottom. There is a place here in Hervey Bay, Qld that speciallizes in plastic work concerning customising bodykits and any plastic work you can think of. See if you can find anywhere that does it in your area. Or drive to Hervey Bay. :/
  • 1 month later...
finally fitted my monster fmic of ebay today and im quite happy with the fitment. everything droped in nicely but i did cut the hole under the baterry and i did have to relocate my washer bottle. apart from that the install went quite well. there is a little bit of lag but its minimal and there is virtually no whistle.. i would recommend these coolers to anyone as they are cheap and reasonable quality. got mine for under 350 delivered to my door.will post a pic or 2 tomorow
well here are the pics of my install.. probably took 6 hours from start to finish. i did swing the washer bottle to the side and i did cut a hole under the battery but i didnt need to touch the front bar reo.. i also chose to put the neo cover back on after a trim.. i managed to guess the first cut almost perfectly as what u see is 1 cut and bolted on.. good way to end the install
they came with the kit.. i was still paranoid they were going to pop off on the first drive as im boosting around 11psi.
i was also toying with the idea of making a stagea specific stencil to spray on the fmic.. nothing to fancy just stagea with unicorn heads..
if anyones bored and wants to design something.. post it up here :P
  • 3 weeks later...
i realise that someone has already asked, but has anyone fitted the just jap stealth kit to a series 2 with a standard front bar. did you cut anything, if so what was it? i dont want to cut out anything visible for the instalation if i can help it.
thank you
I just bought an aftermarket xr6 intercooler for $150
What would be the best way to go about the piping
should i buy a piping kit and get it cut up to fit
or get my mechanic to bend a custom piping set?
  • 2 months later...
Alex,
I guess it would bolt on for a S2.. I've just brought one for my car and will be putting it in very soon. when I do it i'll take some photos. I brought the R34 kit i'm guessing it should fit (just now Just Jap have a Stagea one aswell)
Steve did you have to trim the reo bar to make it fit or was it a straight up bolt on job
BUMP BUMP BUMP! pics please, im looking at changing my cooler and filling the whole thanks :(
BUMP BUMP BUMP! pics please :):(
  • 3 months later...
I fitted a C34 Just Jap cooler to my S2 RSFV on the weekend. No major hassles, everything seemed to fit well and im happy with how it fitted :)
I used the supplied brackets for the bottom of the cooler and just bolted the top to the reo bar, spun the water bottle around towards the front and trimmed the engine cover to suit.
I fitted a C34 Just Jap cooler to my S2 RSFV on the weekend. No major hassles, everything seemed to fit well and im happy with how it fitted :laugh:
Nice job man! From the pics I'm guessing you bought the Cooling Pro Type 1 or Type 2 Kit? Was there a noticable power increase after fitment?
  • I'm keen to get the 'Stealth' Series to fit to my Series 2 with 'Dayz' front bar. I know other people have asked, but no-one has yet responded....Has anyone had any experience fitting a 'Stealth'? Are they really a direct fit to the factory piping with no cutting or fabrication as stated in the ad? (I'm not the most handy bloke in the world unfortunately :) ).
  • I've noticed that the Stealth is a bit smaller than the Type 1 or 2 kits. Would this difference in dimensions reduce performance substantially? I'm guessing a tune is required after fitment also. I have a factory ECU; does this have to be adjusted or anything to suit the new modifications?
Many thanks
if JJR say it is bolt on then it should be a close thing. if no one has done one then you are in the lap of the gods BUT it should be straightforward enough allowing for some minor trimming of the front bar.
the size of the FMIC will be absolutely fine. most FMIC's are larger than required for the power output which has a small cost in response for the extra size.
Thanks for the response Wolverine. I was just speaking with Dan? from Just Jap - the Stealth 'coolers require minor cutting of the REAR of the bar, so nothing visible from the outside. All connectors, clamps etc are included too and it should just connect on to the factory plumbing.
Why the Stealths are more expensive, even though they are smaller than the Type 1 or 2 coolers I have no idea? I might order one later this week and let you know how it turns out.
Tom, can you let me know how the install works out. I have a dayz edition and keen to fit and intercooler, but was concerd about the cutting of the bar. Let me know how it works out and what cooler you went for.
Cheers
Tune isnt needed after fmic if you only have stock computer (ecu) this is becuase their isnt much they can tune without a piggyback ect....
Just reset ur ecu after so it goes into self learn mode for a while (remove positive and pump brakes a few times to drain all power)
I have tidied up some trimming done on the bar on my R33 with a small wood plane (I'm not saying this is the best tool but it worked quite well and was just sitting in the garage). It had been hacked pretty roughly with some kind of saw by the original owner.
The stagea had more or less been professionally done with some linishing of the cut edges. (except for the number plate area that was cut out completely).
The IC will end up fairly close to front reinforcing bar so having a slightly small IC height-wise makes little difference anyway with regard to airflow and it will save you some time/coin cutting a new hole on the drivers side and modifying the engine cover etc. So it might cost more for the kit but will be easier to install. Swings and roundabouts.
Cheers
No problem 187,
I will post some pics & info once installed. I ended up purchasing the 'Stealth' model; I should hopefully recieve it before this weekend.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
