  • 3 weeks later...
i finally took my hicas out last weekend, took all the hosing, and units out and plumbed the hose back to the breater hose in the front where the 4ws actuator was, works like a dream, just have to take the hicas bulb out of the dash now...
I'm pretty keen to do this, just one question though. Is it better to lock the back up with a lock bar, or with the washers (in weight saving, and strength). I'm guessing that the washers will be fine, just wanted to double check though.
I found a HICAS ECU pinout, and wire 20 is the warning lamp, so if you cut that, it should save pulling the dash out.
Edited by sav man
  • 3 weeks later...
Any chance you could share that pinout?
I really wouldn't mind having a good look at that.
OK.....
i have a picture of the HICAS solenoid i hope the picture can make sense for me and all the other HICAS frenzie removalist out there..
http://image-cache.skylinesaustralia.com/f...-1140862108.jpg
Join the hoses you marked in red and the rear stage of the pump will just feed throught the cooler.
I am confused. My lines have small hose for hose #1 , and large hose for hose #2 ....how are you supposed to join them with a simple 150mm long hose? I must have the wrong line, but I have followed the directions right as far as I know? It looks to me that #2 is high pressure...there is no-where to attach a normal rubber hose without making a fitting ?
If it is the right one, I have no idea how I am supposed to get the hose off there with the metal clamps.
The top of my engine bay looks like the picture posted by meep.
Picture1 - http://image-cache.skylinesaustralia.com/f...-1140862108.jpg
The underside looks like this
Picture 2
http://home.kooee.com.au/exup250/hicas.jpg
I could disconnet it under the car, then run a longer hose up, and use a fitting at the bottom...but this doesn't seem right based on what SydneyKid is saying?
I am worried I am about to rip out the wrong hose. either that or the wrong place, cause i can't see it being a 10 minute job like SK made said
Is the line in red the right place to put the link?
Picture 3
http://home.kooee.com.au/exup250/hicas1.jpg
Edited by eXc
Picture 2
Picture 3
Let’s get the terminology right first then move onto what to do.;
1. High pressure hoses DO NOT HAVE CLAMPS, they have compression fittings. So any hose with a compression fitting on it is NOT low pressure.
2. Low pressure hoses HAVE CLAMPS.
3. What you are doing is joining 2 low pressure pieces of (standard) pipework with a piece of (aftermarket) rubber hose that has a clamp at each end to hold the (aftermarket) hose onto the (standard) pipework.
4. The fluid supply and return to the power steering cooler is LOW PRESSURE, so it has clamps.
5. Follow the power steering cooler (standard) pipework and (standard) hoses and note where the (standard) pipework joins to the (standard) rubber hoses. Note that there is both a supply from and a return to the power steering cooler, the return is LOW PRESSURE.
6. Go to the power steering reservoir and follow the (standard) pipework for the return of the fluid from the rear solenoids. The standard pipework goes under the engine, clipped to the subframe.
7. Join the output of the power steering cooler (standard) pipework to the (standard) pipework where it pokes up from the subframe. It needs around 100 to 150 mm piece of aftermarket rubber hose and 2 clamps.
Sorry I can not put up a picture, so please don’t ask.. My own R32GTS does not have the pipework in it at the moment as I am changing to a larger power steering cooler.
Hopefully that is of some help.
:thumbsup: Cheers :wave:
Edited by Sydneykid
  • 1 month later...
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
