Alrite i finally got round to taking some pics. The line in RED is the new bit of hose you need to put in. Its important that u got some oil resistant hose, and it needs to be big enough to slide over the green steel pipes. I also took a shot front on to show the 'cooling loop'.
If theres any more questions, ask away :)
ok, there is a smaller powersteer unit ,in place of the factory on with 2 ribs for the belt,all other hoses have benn removed including the hicas pumps,and computer there is one hose coming from somewhere under the plenium
ok , lock bar in back all power steer lines up front have been removed, and smaller power steering pump is in old ones place ,any ideas as 2 why the steering would b so hard? anyone done this type of conversion got any ideas?
ok found the problem, the solonoid the opens to control the powersteer isnt opening at low speed,applied 12v to it and it works perfectly,so its either not connected,to the controller or the controller is buggered, does the p/s run off the hicas computer as well or a seperate controller?
  • 5 months later...
What would happen if one removed the rear steering rack with the lines that run into the "junction box" (I've got no idea what to call it!) and simply put 2 bolts into the holes that the lines came out of?
The power steering pump rear rotor would fail
:rofl: cheers :thumbsup:
I think this might have finally happened... now getting a grating sound kind of like honing metal on a lathe or drilling stainless. Time for a replacement and bypass loop hose.
ok i know we have been over this 400 times already tonite but with reading sooooooo many slightly different ways, i just want to know if this a correct way in the pics below.....
thanks for your imput.
i have been reading this over and over, whats left of my little brain is gettting confuzed.
What I did with my ps pump was ...
As it is modular, removed the rear section off it , shortened the main shaft and re hardened it and put it all back together with the entire rear section removed ...
Another really easy solution is to simply remove the hub and vanes from the rear part ...
Seemed easier than adapting another pump to me ...
Have a look through here, just ask if you're still a bit confused
http://www.nissansilvia.com/forums/locking...13-t185697.html
It's all well and good to remove the rear powersteering pump rotor, but if you keep it on, it does make plumbing in a p/s cooler a bit easier. And keeps the functionality of the stock cooler :)
robbie,
the way it's show in the pics is the easiest way to remove the hicas from the loop. Salads write up on NS (thats he's linked above) covers it all aswell.
Once you remove the fittings from the hicas solenoid in the engine bay it becomes pretty obvious which hoses have to be joined up as there are only 2 loose ones once everything else is removed.
robbie,
thanks BHdave,
it was a long day yesterday, i went and looked in the engine bay(made easyer with no motor in it) this morning and yes its very easy, i was just being lasy and trying to work it out without looking in the bay and trying to work it out using the diagrams....
thanks for the advice..
  • 1 month later...
Bump as this is a good thread.. and the ns link is probably the best btw.. Just did this on my GTS-t over the weekend.. Seems to be ok, but needs a wheel alignment badly now so bit hard to tell the final result.
Here are a bunch of pics I took to help anybody along, and everybody seems to suck at the pictures (macro-focus button people!). Note that this is an R32 GTS-T, which obviously will look a bit different to the GTR, but the process will be the same.
My tips are, make sure you remove the battery, use a drip tray and you can get away with not making any mess at all, and remove the piping near the gearbox slave cylinder first by undoing the 2x pipes where they have a screw point. Remove back up to there, let fluid drain out, then remove front part of system. Some people seem to have chopped the return way back near the power steering pump - not quite sure why you'd want to do that, as to me metal pipe > rubber hose.. and you can just then use a shorter piece of hose up near the battery end, which can easily be replaced if it perishes later on.
I like the fact that there is just less crap on the car now, and as you can see there is a lot of crap in the system. Also makes it much easier to reach the oil filter and a few other things too. Weight is around 15kg saved.
It is actually fairly time consuming. I'd set aside a full day unless you have done it before.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
