  • Replies 46
Posted Images
two bay with carports in frount. biggest size bays you can get. I have normal (not sure) size bays and its a bit squishy with a car and a worchbench at the end. Dont bother getting a tall one.. at least 2 bays, best bet would be three if you can fit it in your yard
- go for 3 bays (2 cars but more room :D)
- remember you will need a spot for engine stand
- a spot for workbench
- a spot for the huge ass snap on tool box
- a spot for sofa
- a wall for a plasma screen
- a spot for beer fridge
- sink for greasy washing up
- might want to look into ventilation for exhaust fumes and heat
- you want to have a roundabout in front of the garage
- and a big ass shelf for all those boxes, n shit
ok a word of warning when building a shed duncan, make sure the ground is solid and there is no top soil 1 metre under the foundation...
bit complex in our situation, but it has caused major problems and headaches, and it was the bloody councils fault
we have pretty much had to dig around and under part of the foundation fill with concrete and place a bit I beam in there to support....
but anyway enough of that, our shed is a quaker barn style 2 storey(upper level is a self contained unit) single roller door, 3 car with a pit, engine chain on a roller, still comming along but its gonna be good.
thanks guys :D
I was thinking either 7 or 8m deep to allow 2-3m for workbench and workspace behind the cars, is that enough or is it going to shit me for years to come?
It will be 3 bays wide, I am thinking 1 single door for the daily driver and a double width door for the race car to live in the middle of 2 bays for plenty of space.
And Eug....as if I would need room for an engine stand :D
that sounds phat_mr30, what size is it all up?
I am thinking nice thick concrete slab as the base, will probably be attached to the house.
What did you need for the engine chain and roller? anything tricky? sounds like a great idea.
When it comes to Garage doors and remotes,you can use a roller up to 5200mm,after that you go into industrial pricing,so you use a Sectional panel door,you can go up to 7000mm.If you go 2 doors you are up for another $450 for an extra remote motor.Most double doors are 4800mm and singles 2400mm,keep the height under 2400mm and you save more money with either door.
ahh yes the hoist.....
I was thinking about leaving that outside the garage, nice cheap second hand 2 poster. Its going to be a bit tricky to get 4m clearance in the garage with the design we are thinking (garage roof is a balcony for the main house). Also, I am worried a hoist will make it a bit tricky to work around sometimes since it has to be fixed in place in one of the spots.
Skyline 4.5m long. Workbench about .7m deep = 5.2m so you only have .8m which I reckon is too close too. But I am a bit worried about 8m long garage + driveway into the garage and how much space that will take out of the back yard :D Its an OK block but not hge and I need some grass left
yeah Kel's bro is a sparky and he said its not cheap either. There are 240v hoists out there but I don't know anyone that's used one or if there are any problems
I don't mind if the hoist is a bit slow as long as it is safe :D
Make sure the entrance is tall enough so that a 4WD can get in (I know sounds silly but I noticed this when we were looking at houses, some weren't tall enough).
Something else I realy liked but settled without was having a back garage door so you could drive into the backyard, store a boat etc. Little things like that might even be selling points if you ever decided to move.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
