Also - helpers are really only needed full time in the morning. So in the afternoon you are free to come and just enjoy the 2 car battles on the skidpan and since passengers are allowed you should all be able to find a ride in someones car for some fun as well.
I can highly recommend Pete and Brisby as candidates for an entertaining drive to be a passenger in.
It's really going to be an entertaining day. Some of the cars entered are going to be worth the drive up just to see in action. Check out the Mirage thats going to be there.
http://www.tufcars.com.au/index.html
  • Replies 70
Posted Images
$900 for an external mount??
Sheez!
I bought mine for $98 and I'll be using it all day inside and outside of as many cars as possible (although maybe only outside mine because I'm not 100% confident in it just yet. LOL)
lol, this is meant for getting further out from the car, rather than close up.
but if need be, i have 3 (non adjustable) car mounts
bring our own reflecty tops?
where do you get them from?
is there a list of people attending with forum names rather than real names?
that way i can take some steps into seeing if ill hitch a ride if i do infact come.
my car might be sold before this event, and im looking for a little buzz box to get me to work...so that wouldnt be the most fun drive to shep
Ok - these are SOME of the entrants user names coming up:
Snowman
CDR RA
Budge
Phunky Monkey
R32 Big Boy
funkymonkey
Blipman
NickR33
Ant95GTR
tom_g
saff_cossie
MissJuz
joelstrict
Scotsman
Roy
Base Junky
matlowth
DavidM
bel180
dave_
Al
Chrisman
RPMZ
ADZMAX
Some of the other coming up just to come up include
Jamezilla
inark
paul33
Bec
R31Nismoid
Leewah
Let Me Drive
And if I've missed anyone feel free to add yourselves.
There - I hope that helps.
does raving gear classify as reflecty stuff i can borrow some uber leet fat pants that look retarded fluro orange :P
Leewah has a whole cupboard full of them.
Only problem is they only fit him and the average 7yo.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
