I had a Gates installed on Thursday. Today I noticed an annoying amount of noise, so I thought I would look on the forum to see if it's common.
"i have heard of people complaining that the gates belts are quite noisy... "
Well, there you go... :(
Edited by clayoth
word up, i agree stocker oem item should be fine, brand prolly doesnt mean. to have timing belt changed is usually around $450 in labour. as have you basically pull heaps of crap out of the way to get it done
Hi, just wondering what sort of noise people are hearing with Gates belts?
I had a nissan belt on my R32(when Nissan were about the only choice available here) and it was quiet, the only noise that came from area was the squeak/whirring sound from the worn out tensioner bearing before I replaced it. I have a Gates on my R31 and it makes no noise.
Gates have made good quality belts for a very long time, my old man always used them on the engines he rebuilt. Possibly some of the noise being heard now could be tensioner bearings. The only other ways a belt can make a noise is if the teeth on it are slightly different profile(i.e. gears worn or belt profile not matching) to that on the cam/crank gears or its rubbing on the guard because it isn't dentralised on the gears.
I seriously doubt that Nissan or HKS make its own belts so they will be coming from a parts supplier like Gates anyway.
The noise I have is a whirring noise. After listening to it again tonight, I think you might be on the money with tooth profile or something similar. I have a Gates belt and new OS Giken gears. Perhaps you wouldn't get the noise with the original gears???
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
