As the title says, I have just finished installing a R34GTT Front Lip... FL was purchased from Carmate.com last week and installed today. Basically, the FL is my solution to the constant front bar scrapage I get whenever going up my own driveway - being a cheap bodykit item; I thought why not. Better to damage the lip than the bar ~
Overall opinion on the product quality was good - even my picky mechanic/tuner said so (most people I know don't rate Carmate products). There was some very questionable mounting "bungs" that were included but they were promptly cut off :huh:
Installation and painting took a total of 4 hours all in the same day - below are photos of the finished product, even had time to go back and fix up bits and pieces from my Front Bar (from FMIC install) that weren't cut quite correctly last time. Now the FL looks like it was there from day one, there is no loose plastic/fibreglass to be found on Bar/Lip.
imgp03868wu.th.jpg imgp03876hx.th.jpg imgp03880cj.th.jpg imgp03896lv.th.jpg imgp03903bt.th.jpg
NB:
I am also very pleased to say that I now have my washer bottles working again :O Universal kit purchased from SuperCheap Auto did the job and surprisingly it looks stock! We removed the original stuff completely and put the 1L bottle next to the battery - perfect fit ;)
https://www.sau.com.au/forums/topic/94638-installed-a-r34gtt-front-lip/
mmmmm, looks hot, damn hot ^^.
Thanks again for the pod filter and BC install, had a blast on the way home listening to the wonderful sound of th pod filter and reving the shit out the car lol. Who needs a blow off, when the sound of induction is even better.
Paint job was $120.00 all inclusive as it was done by the guy opposite my mate's workshop. Total cost of the project adds up to be $400.00 (part, paint and fitting)
Even though this is verging on $500, it is still considerably lower than the East Bear product - personal preference and wallet size I guess ;)
I think if I had bought the lip via Group Buy as once suggested, I would've got away with $380.00 all up - but $20 oh well :P
Hey dude,
Thanx for the info regarding the water bottle, I also had the same problem when I installed my FMIC, ill have to go past super cheaps and get one of those kits.
Overall opinion on the product quality was good - even my picky mechanic/tuner said so (most people I know don't rate Carmate products).  There was some very questionable mounting "bungs" that were included but they were promptly cut off :angry:
NB:
I am also very pleased to say that I now have my washer bottles working again :)  Universal kit purchased from SuperCheap Auto did the job and surprisingly it looks stock!  We removed the original stuff completely and put the 1L bottle next to the battery - perfect fit :)
Looks just like mine except for the intercoolers. The car came as it is from Japan stock standard. Just ordered the Blitz coolers and enjoying modding it month after month. I like your clear indicators mate. Enjoy ur drive!!
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
