  • Replies 86
BP and Mobil, use either Shell or Caltex Fuel. Either way you going to get caltex or shell.
I never use to put anything but Optimax or Vortex (98) in my r33, till i found out they basically come from places. :P
What month is the HPI mag?
Have a read of the new HPI,Donnon picks up 22rwkw in a GTR tuned with Ethanol 98,also 10c a litre cheaper.More power,less cost.......no brainer.
Which mag was that one?
I just went and bought HPI (there was a 1 + 2 pack) so i grabbed it, it was the only one there.
Is it in there, the article? Which one of the three mags? the one with SIL80 on the cover?
I've spoken to someone who's been working at the BP refinery (but not for BP) and although he wasn't able to make any comments he did say that there's something going down. But he didn't think it would take ages to fix, maybe 1 to 2 weeks?
"They taste like burning!"
HPI issue 60 page 69.The fuel is known as E10 and you get it at United.The one in Mornington has had it for 3 months.I paid $1.15 for it last week.I'm going to get Ice to do a back to back dyno tune with this stuff,hopefully this week.
wierd I just filled up with 60 litres of BP ultimate from the BP next to my house.
Maybe its only state specific?
It has been established on multiple occasions that it affects WA only. Im pretty sure the Eastern States can get Premium from other suppliers.
Edited by Big Rizza
larger population @ eastern State...and cars too...so BP wuld desert smaller parts....W.A too far nyways..are there refinary here?
and so here I am stuck with Octane Boost + super unleaded(Shell ones).....
don't feel as good as pure bp ultimate...maybe phsycological..but seem slower.. =(....BP ran out of their Super as well...I gotta go Shell..
This sucks. :P I have enough fuel for tomorrow, then I will be off for 2 days & will drive either nowhere or in my pos. Hopefully there will be some by the weekend as some have said, but with others saying the end of this month, so many cars are going to need a retune. :(
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
