Hey guys,
I have just got the car back on the road. Had standard turbos before, and now have Garrett ball bearings that are about the equiv of N1's. Additionally I have Mines dump pipes on there - where before I just had the stock items.
One thing that hasn't changed, which I had hoped would - is that there is noticeable lag between changing gears, even when changing up around 7000rpm.
I have HKS SSQ bovs which were already on the car when I got it.
Is this normal?
I would have thought that once a pair of ball bearing turbos had the RPM up, that they would have reasonable inertia to keep going? Or is it because when the bov's fire, I have to 'refill' the Intercooler? The Intercooler is an Apexi Hybrid and is a bit bigger than standard (not sure 'how much' bigger)
https://www.sau.com.au/forums/topic/95426-lag-between-gears/
what do you deem as lag though???
there will be a small period where it needs to build again, but it depends how long you take to change gears etc.
Thats the main bit.
Faster you change the less time there is inbetween etc
Ive heard some people change so fast i can hardly hear the BOV give more than a little noise rather than a full dump before they are back onto the throttle. :P
i'd say its more driver being nicer to the car than anything.
If i snapped a gear fast i could hardly hear mine go and it would rocket off. But then i could also take a second to change a gear and it would have to build again
my old turbosmart dual stage had a problem with it, on low boost it would keep the wastegate open for a long time after gear changes and took at least 2 seconds for it to close and make boost again. on the high setting if was fine and made boost straight away, just something for you to think about.
Cheers for all those answers guys,
tighten your BOV a little, and see if that fixes it. Then maybe a little more if it doesn't.
I'll have to look at the HKS Bov's to see if they have some sort of adjustment and then have a play to see what results I get.
I guess its true, my question is a little bit like "how long is a piece of string". Everyone has different ideas about what is and what is not 'acceptable' lag. I can do ultra fast gear changes though, and yes this alleviates it a bit, but on the track, to be 'nice' I probably do something like a half-second to maybe 1 second gear change? Not super fast... And it falls back to about 5000rpm and then seems to start building boost again. Since my turbos are still small (GT-SS size) I would have thought that will still have them on song...? I am wondering if it is filling the intercooler again.. perhaps I have TOO much BOV? Could that be the case?
oooo... All installed? How's it going?
Hey there Lucien, Yup! I'll have to PM you all the details! :( Hows the Thesis coming along?
well bigger turbos push more air and so dont make full boost until higher revs....so maybe when you change down the revs are too low to make full boost now
Yeah I agree, but since they are "already spun up" and I am just changing gears, wouldn't they more or less keep going? I mean, these things are ball-bearing and going at 150000rpm.. how come they slow down in a half second gear change?
How does someone figure out if you have too much BOV (emptying the Intercooler), or not enough BOV (stalling the turbo) ?
my old turbosmart dual stage had a problem with it....
Hmm... I think I really need to suss out these HKS SSQ's on the car first and see if there is a problem first..
Cheers guys, if I find the 'issue' I'll post it up for sure.
probably aftermarket turbo's you went to are more laggy - due to heavier exhaust wheel (compared with stock ceramic wheel which is also smaller)
Yup, and I agree that they may take a little longer to spool up first try, but then the opposite is true too once they are spinning. Since they are a little heavier they have inertia and so should take just as long to spin down as they did to spin up shouldn't they? And given that nothing is 'applying the brakes' to them they shouldn't fall off that quickly I wouldn't have thought..?
There has to be something wrong somewhere. Maybe I need a smaller intercooler.
Well theres 2 things that might feel like lag up
1/ how long it takes to go from 0 revs to full revs when it has enough air flow. This would be like when you mash the throttle at high revs
2/ what rpm it makes full boost at.
I suspect what you are noticing is 2 not 1. 1 is generally a very short space of time, while 2 depends on what the revs are, where you start, and how fast revs rise.
I hope my rambling made sense
Hmm. Well I had it flat out at 7500rpm (so the turbo is fully spooled making maximum boost) and I change gear and mash it again. The tacho falls back around 5000rpm.. and then it 'winds up' again.. I would yhave thought at those rpms and air-flow it should be straight on boost again?
Ok, this I am not sure. The boost gauge and boost controller got taken out when I fitted Motec, so don't know exactly what RPM full boost arrives, but I would think well before the 5000rpm that I am falling back to when changing gears yeah?
I'll be refitting the gauge and checking out the Motec logging to see. But don't have that data yet...
yup! :(
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
